Hitch wiring question - 4 pin
Schwartb01
Barry
2022 Wildtrak; 2018 Ram Cummins Diesel; 2018 JLU
I've installed and wired an almost identical aftermarket hitch to a previous Jeep. Trailer lights functioned off of taillight tie-ins. I ran the power wire through vehicle and firewall, as instructed, to battery. I am thinking this 12v lead is not necessary and only functions to power a battery on a trailer that may have electric brakes. Anyone know of any other purpose for the 12v lead to battery or can it be left off? I read in ONE place that some taillight setups can't handle the amps of the trailer lights being tied into the vehicle taillights but that doesn't seem right. Any advice is appreciated.
dgorsett
colorado
F250, Mustang, Explorer
IDK about your Jeep set up, but with the Bronco the 12v lead is needed because the factory taillights will sense the extra load and will not like it. Other folks here can explain the why of it.
Schwartb01
Schwartb01
Barry
IDK about your Jeep set up, but with the Bronco the 12v lead is needed because the factory taillights will sense the extra load and will not like it. Other folks here can explain the shy of it.
Thanks! Yes, I read that and with LED's I know things are sensitive to what loads they see.
Schwartb01
Schwartb01
Barry
Follow up. Anyone have insight on how they wired to 12v. Last time I removed interior panels from rear all the way to front and through firewall. Anyone route under vehicle? TIA.
dgorsett
colorado
I ran mine in plastic loom along the outside of the left frame rail above a factory wire loom. I ran mine with a four wire I needed for taillights when used behind my RV.
guzie
Kevin
Grand Rapids
2019 Subaru WRX sti, 2019 Ford Mustang GT
Here are the instructions for wiring the ford 4 pin kit.
AZSky
Scottsdale, AZ
Heritage, Mach E, EV6
Can you explain the detail ?
I have the Curt hitch installed and their 4 wire adapter waiting for install, procrastinating..
I have a trailer with electric brakes coming, so would need to do everything correctly in one step :-0
Schwartb01
Schwartb01
Barry
dgorsett
colorado
You will need a seven pin set up, or the Curt plus a custom or homemade 3 pin. I only have experience with the plug and play Curt 4. I'm sure others here can help.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Yes, I also routed on the outside following along the wire bundle that runs along the left side frame rail. See video linked here for full installation process. The 12V routing starts at 13:00. Let me know if any questions.
