Administrator
Administrator
Staff member
Doug
At the Michigan Assembly Plant (in Wayne, MI), which will be producing these beasts :)
The 2 Door is on 37" tires (BFG 37/12.50R17) and factory 2" lift kit.
These are available for public viewing, so go see it!
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115985749_4677762612241263_3460773688231217044_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115941406_10219670920496898_8714459240222946034_o
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115843782_2623544887915265_8651281505008949427_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 108959461_10219671414549249_8394275231144479166_o
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115970313_10219671415069262_1640957130735284817_o
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115909650_10219671414709253_1082318834053927252_o
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 109298693_10219671414309243_7033611384668810412_o
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 109563053_10219671413989235_3231141862075374929_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 116019288_10219671417709328_329307933383263974_o
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115868508_10219671419149364_8529633542765184887_o
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115824857_10219671419989385_6719294281552979180_o
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 109924380_10219671417949334_308288269601212059_o
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 116003156_10219671420349394_4100870181708407849_o
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115821135_4677685758915615_4482410879464042004_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115929635_4677685642248960_3267261433860425730_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115821721_4677685548915636_5967447916819675702_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 116015883_4677684995582358_8676977045197037891_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 109294290_4677685115582346_8035484983602067330_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115682221_4677685875582270_6799084454508637142_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115966369_4677685628915628_2322559573482119629_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 116019359_4677685065582351_1114683495083354081_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115843985_4677721978911993_7389316817198045372_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115912035_4677684965582361_5535670830146027052_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115821721_4677685548915636_5967447916819675702_n-2
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 109294290_4677685115582346_8035484983602067330_n-2
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 109589512_4677773235573534_2969028004238960655_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115820883_4677762462241278_2116776361484655677_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 115820886_4677762688907922_6795114809979928090_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 109109907_4677762522241272_3349457082410665189_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 116018908_10219671816319293_8797553870234084889_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 116009570_10219671819399370_9007094076895678067_o
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 116021231_10219671817639326_8826079626802829682_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 109352634_10219671818559349_4711422630744124559_n
Ford Bronco Homecoming! Launch Broncos (4 Door Cactus Gray & 2 Door Cyber Orange) on public display at Michigan Assembly Plant 109760594_10219671818879357_5180956008135154468_o
More pics:
The first guy is 6'2" tall for reference.
VGK_Fan
Henderson NV
2022 Audi S5 Sportback, 2021 Bronco Badlands
Man I'm going to be so disappointed if I can't get a 2 door in the same trim as the cactus gray one. The grille, the dash, the seats, everything
Nickp
Nick
Phoenix
Rear legroom in the 2 door doesn’t look bad at all. That was one of my huge worries that it was going to be like a Tacoma, but looks perfectly serviceable.
bbq4133
2020 JLUR 6MT
Every time I see the Cyber Orange one I remain hopeful that Ford will #SaveTheMansquatch or, at the very least, allow me to add a lift and big tires to the Badlands when ordering in December. I will never give up!!!
BoneyRoads
Cory
Waco, TX
21' 2.3 MT
The more I see cactus grey the more I think about switching from antimatter blue...really want to see Area 51 in the wild too
EvlNvrDys
Hunterdon County, NJ
At the Michigan Assembly Plant, which will be producing these beasts :)
First off, the one on the left looks huge, looks beautiful.. I'm guessing those are the 37's correct?
Now my complaint, can we get someone taller that 4'6" to stand between them. I get we want them to look bigger and all, but seriously, this makes it look like these things will be crushing cars in some arena.
Edit: BTW, these prototypes are all over for everyone to take a pic with them. How about we get back into the factory and START PRODUCING THEM!! That's all. ?
Ripcurl
DodgeRam 1500 Laramie, HarleyDavidson 48
To me the 2 door looks optically larger in some of the first two photos.....is it the orange color or slightly closer positioning playing tricks? I thought they were both Sasquatch.
codydb19
Cody
Silverado
Yeah it looks much bigger than I had anticipated! I've been a 4 door guy since the beginning, but as soon as I saw that pic my mind immediately went "ohhh I could make a two door work"
codydb19
Cody
Silverado
No, the 2 door has an additional 2 inch lift and 37s. So your eyes are just fine lol.
Toccoa
Isuzu Rodeo Sport
They've returned home!
