How can I get a 12" sub or 2 10" subs while keep my bronco interior OEM looking
Erock
US
2018 F150 Alpine edition
Or potentially under the rears. I realize they will for forward and down but I'm guessing there is actually quite a bit of empty space "inside" the rear seat bottoms.
They’re trying to avoid the rear seats, because of the fold flat, I believe
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Center console? I've heard it's big enough for a fridge.
Jokes aside, I've done the rear under-seat box on a 40/60 rear seat and didn't get to use the 60 side. It wasn't the worst.
I'm wondering how much room is behind the plastic walls in the back, that might be an option. I'd be OK with a single 10.
elmystico
Jon
New Mexico
2014 FJ Cruiser, 1990 Toyota pickup, 2021 Audi Q8
Well, $900 is a lot less than the upgrade price to a trim level with the B&O audio. I know the JBL can be wired, but it's also a Bluetooth speaker, which could be handy during your outdoor adventures. Also the ability to detach it or flip it rear-facing if needed. I wonder if you can broadcast Bluetooth audio from the head unit to the speaker, or if that's a one-way trip only and you'd have to run wires?
Yeah, not trying to debate the functionality/quality. Just saying, $900 is a lot. They do have 3mm and RCA inputs.
jsharpe
www.sharpe.com
Prius
I understand that but I was assuming that they were thinking that the rear seats weren't an option because when folded the space below them "goes away". I was merely pointing out that there might actually still be usable space there even when folded. Of course we don't actually know how much space there might be since I don't think there have been any pictures of the underside of any of the seats, from or rear.
Zhilyard
Zach
F150, Scion TC
Love the insight guys, I'll look into the little space under the cargo area if my best option for sound is to use the lower cargo area (means I can't store my doors and roof in the back anymore) but sounds more important, and yes the bazooka is like a last ditch effort, but probably a kicker bazooka if I had to. My f150 has 2 JL10TW3's great sub.
Sandbergo
Jelani & Dave
Orlando
Rogue
I’m looking into getting either a JL Audio 10TW3 or a 12TW3 and doing a custom box in the location where the factory sub likely is.
Zhilyard
Zach
F150, Scion TC
Im hoping this is a possibility, if I could get a box fiberglassed to fit in the same area but have enough cu ft. For the sub to work well that would be ideal, (and I like a little extra cu ft for the 10tw3), let's the sub hit a fuller range than the recommended .6 cu ft.
R11
www.basequatch.com
Bronco Base Sasquatch 2.7
I love the Cerwin Vega spare tire sub I have in my VW (https://cerwinvegamobile.com/produc...-vega-enclosures/12-powered-active-subwoofer/). Shame the Bronco doesn't have an interior spare tire. I can't remember: does the new Bronco have any type of under-floor storage area in the cargo bay?
I don't know - an interior spare either pushes into cargo space or pushes out into the underbody area, where things are (at least somewhat) arranged to maximize clearance, so I'd rather not have an interior spare. I was underneath the dealership appearance units this weekend, and I don't think there's space for the latter at all, especially considering Sasquatch from the factory, and nobody would be happy with less interior cargo space lol.
Under-floor: Yes. Here's the only shot I got of that space in a 4 door. I recall seeing better pics here somewhere.
Altitude
Howard
Papillion, NE
2015 Grand Cherokee, 2008 Suzuki B-King
I'm imaging a custom sound bar type fiberglass enclosure for 2 8s or 2 10s with 6x9s or 6 1/2s that replace the two rear pods mounted to the rollbar and goes across the entire width. I always do some sort of aftermarket system in my vehicles, and the Bronco will be no different. We'll have to wait and see what, if anything, the aftermarket comes up with for off the shelf solutions. The Bronco will be more challenging than my previous builds though there seems to a large selection of decent quality marine grade audio components available.
Rusty Sheckleford
America
Ford Escape
A few others have already mentioned this, but I really like the idea of creating a load flat floor with a subbox in the bed.
My dream build would be quick disconnect wiring, and to perhaps design some kind of lift system so the entire box can be raised to allow access to the rear underfloor storage. Would also want tiedown anchors on each corner.
I'm doing a custom sealed downfire box that is the entire width and depth of my 2 door cargo. In essence, it will look like a raised floor or the accessory cargo tray. If you go shallow mount, it can be around 6" total height with standoffs for the downfire setup. Plan is 2 10's. Unplug the amp and pull the box out if you need a little more space for camping gear etc..
How does downfiring sound? Does it muffle or hurt the sound quality?
I guess it doesn't matter, since that's really the only way to go if you want to still be able to put big, heavy things in the back without always removing the box.
edgeflyer
2013 FX4
Ooh no, Downfiring increases felt bass by 20%+. And I'm not kidding. Just Make sure you have room for the subs to flex without hitting the floor of the truck. I also like to leave a gap in the front/back of the box between the sub and floor for air to escape when hitting hard or fast. Downfiring also lets you have a solid cargo floor again. I will probably get the factory mat to put on it.
mds5917
New Jersey
'21 Bronco Badlands, '21 Toyota RAV4 Prime
jsharpe
www.sharpe.com
Prius
It would need a mod to the covering panel but I wonder if something like this might work in place of the storage tray in front of the jack. And if not there, perhaps inside the bottom of the wider rear seat bottom. It looks like it needs about 6" of height.
edgeflyer
2013 FX4
Yeah, but those boxes are limited in airspace and leave performance on the table. I am custom building mine.
