How do bead lock rings work ?
broncoSJ
NJ
2021 Ranger
How do these work? Just bolt onto the rim with Allen bolts? Come in different colors? Please explain.
brrke
Vancouver
1997 NA8 Miata
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
From the factory the rings are just for aesthetics.
If you want proper headlocks, you buy replacement rings from the parts counter and swap them out. (The rims are “beadlock ready”)
Incognito
Phoenix
2017 jk
Respectfully, the factory rings as delivered, are more than just cosmetic.
They are Rash Rings.
They help protect rim from rock damage when aired down.
They can be converted to Beadlocks.
But it's a bit of work and money.
Our Federal betters don't allow Beadlocks straight from the factory.
Inventor
Do you know why beadlocks are not allowed?
Inventor
Nope.
Do tell. ?
Someone said that in a crash from the side there is a greater chance of the vehicle getting a grip on the road and flipping vs non bead lock that could de bead and slide.. something like that but I don't know for sure.
Incognito
Phoenix
2017 jk
Well, I'll take your word for it.
It is afterall the government making final decisions.
But.....
Ford Bronco How do bead lock rings work ? BackBrightKakapo-size_restricted
Inventor
But.....
Another forums says " the reason beadlocks are illegal is b/c the bolts would get loose and then the rim would separate (i believe it was already stated). but some manufacturers have come up with a hold down system (bolts) that does not loosen when driving at 70 mph!"
Incognito
Phoenix
2017 jk
How's the old saying go...
If you have to ask....
No disagreement. But,......
Most posters and lurkers here don't know that cast aluminum rims are nearly impossible to repair, once damaged.
Rash rings and the beadlock rings take the hits, and are replaced, in cases that would put a regular rim in the scrap bin.
AK SNO RIDER
Ty
Alaska
I'm sure it has more to do with beadlocks being more complicated than a typical wheel. They aren't set and forget. You have to know how to use and maintain them. Most people won't. Your typical tire shop won't touch them, most wouldn't even know what to do with them.
We don't need people losing rings and de-beading tires on the freeway.
Then again, tinted windows are illegal in lots of places, so there could be literally no reason. Sometimes I think the lawmakers just set up a roulette wheel with random crap on it.
Inventor
I asked on another thread but no answer . Can you put hotrod wheels on the bronco and put the 35s on them? Are they more likely to slip the bead off road?
Ford Bronco How do bead lock rings work ? Screen Shot 2020-10-13 at 10.26.05 PM
