How do you plan to mount your Hi Lift jack?
2ndgenirish
William
Ford Edge Sport
I have not seen any Bronco mounting kits for a Hi Lift jack - lots for Jeeps.
What are your thoughts on where and how to mount a jack?
Which length jack do you plan to carry? They come in 35", 48" & 60" lengths.
I have given up on a winch. I see a jack as a good solution.
Advertisement
Bad Andy
Andy
Anaheim, CA
2018 Volvo XC60 T8
I have been looking into this as well. I am guessing maybe mount to the modular bumper, but would want to look at mounting holes and options.
I don't expect to get my 2 door until next Spring or early next Summer, so I have time to figure it out.
Theherofails
Thomas
Phoenix
2021 Audi Q7 Prestige, 2021 Ford Ranger Tremor
I wonder if it will fit under the rear seat of the 4 door? Secured of course. But its a thought.
If so, it will likely interfere with the seats folding forward. I seem to recall the seat bottoms sliding forward and down to make room for the back but I wouldn't mind a correction if I'm wrong.
So my guess is it would be an either/or situation if its possible at all.
MaverickMan
Shane
Yeah if the seats are folded then you got more room in the back. Sounds good to me.
Tech Tim
Tim
Wet Side of WA
Jeep JKU
Will be mounting the Hi-Lift outside the vehicle, probably on the rear bumper. Will see what the ARB rear bumper looks like when it shows up.
I gave up on the shorter Hi-Lift jack lengths and have gone to the 60" model.
It's longer, so harder to store inside, but to me the benefits outweigh the storage problem.
The longer length allows you to get a better hold of it when you are jacking, giving you more support. It also gives you a longer track to winch along if you are using your jack to winch, so less rope/chain resets while winching.
Felix808
SRV CA
Waiting for 4-door Badlands Bronco
I reached out to Hi-Lift a while back & they are working on mounts but I intend to use the trail Trak system that is for the JLU if they don't have something similar out for the Bronco.
ICUGAZN
Kevin
2019 Raptor
That is a nice system. I hope that do bring that to the Bronco.
Felix808
SRV CA
I've asked them to ;) but it will still work. You just won't have a Bronco Specific template when drilling your holes & will just have to measure it out.
Werkedperformance
Philthy
www.instagram.com
03 FX4 Level 2
grayshadow
Charles
Humble, Texas
2017Honda Civic SI
Vehicle Showcase
grayshadow
Charles
Humble, Texas
2017Honda Civic SI
Vehicle Showcase
If I decide to go with a Hi Lift jack I will carry mine on top of my Yakima platform but, I understand this may not be an option for everyone.
redone17
Cold Spring, NY
2021 Bronco, 2016 Transit Connect
I’m pretty sure only the 36” will fit in the back of the Bronco that way. Mine JUST fits in the back of the cargo space horizontally. I bought the 42” first and returned it…cargo space is precious. I’ll take some measurements tonight.
Felix808
SRV CA
it should fit no problem as the Bronco is wider. Also note they moved the clamp & removed the foot of the jack, but measure all the same please ;)
Advertisement
Middleton Motorsports
Advertisement
