How Many Units Can The bronco MAP produce per month ?
Frank
Norwalk CT
Toyota 4 Runner 1988
Ignoring Commodity constraints ?
My Rez is 2O k in line, Buildable from what I have read here.. Just want to see if I can actually get it before it snows
johnston.zach
Milwaukee, WI
2010 Chevy Impala
What do you mean your rz is 20k in line?
King Du’Vey
Frank
Norwalk CT
Michigan assembly plant builds the bronco and the ranger.
the plant can build 5200 units a week according to wiki. thats a fairly ordinary rate for 2 shifts.
but that capacity must be divided between Bronco and Ranger, and ultimately commodity constraints for everything will limit throughput. we talk about the constraints that stick out, but theres a water level for bronco where every part would be constrained if you tried to exceed that amount.
Thank you.. Good to know! Hopefully constraints lift soon for all of us!!!
jaruss01
NJ
Dont forget the ~5k demo builds and ~3k priority builds that are in front of you (before accounting for your estimated # ~20k timestamp). Plus the 7k FEs that need to be disbursed throughout the 2021 model run (excluding those guys that opted for a mod top going to 2022). And production will be cut short through August. So if you run the numbers starting 5/3 with 500/week ramping up to 2,500/week in August (and there forward), factoring in the builds in front of you (noted above), you could start to get a better sense of where you will shake out. Although thats assuming all things being fair. Right now it's a bit of a crap shoot.
