How to check transmission fluid on a sealed tranny?
beachrat
Rick
2023 Bronco
Hi All. took a little bump in the rear, enough to cause a new radiator to be installed after pushing me into another vehicle! Where do you check transmission fluid on a sealed tranny? Cooler leaked out now I have a code. Any Help?
Fordified1
Bob
Mid South Texas
Above the pan rail passenger side I believe.
beachrat
Rick
2023 Bronco
take a look thanks, dealer said under shift linkage but didn't locate it! I guess a dipstick is to easy!
broadicustomworks
Hanging Rock, North Carolina
Driver's side.
Near the rear corner, above the pan is an 19mm plug.
It feels like it is on with 350 ft/lbs. of torque mainly due to not a lot of room for a ratchet wrench to loosen it.
Inside/under it is a plastic dipstick that fits in the hole.
Numerals that are difficult to see without bifocals on there.
Cold level should be at about the first round dot numeral ( I think it is 6?).
broadicustomworks
Video I found states it is a 19mm. And now I remember that is correct.
It also states to check it hot, at operating temps.
NOT Bronco specific, but same trans.
broadicustomworks
Fordified1
Bob
Mid South Texas
I assume you have to check it while it’s running also.?
Ducati1098
pakrat
JG
Lake Tahoe
Toyota 4Runner-F250-Tundra
Yes....and at temp. You will definitely want to wear a thick long sleeved shirt or you will burn your arm reaching in to grab the dipstick (it's actually a dip toothpick size). I tested this for you and learned a lesson.
beachrat
Rick
2023 Bronco
Driver's side.
thanks got it!
