HOW-TO DIY: Bronco Door Caddie Holder w/ pictures/dimensions
88to21bronco
Tennessee
2017 Nissan Titan XD
I finally got around to making a caddie for the doors. I had been putting them on the couches in the mancave...not ideal. Eventually I will get door bags, but this will do until then.
I bought these at Harbor Freight...I went to buy wooden ones but these were cheaper ($25 I think). As you will see, they are metal reinforced...good stuff.
Ford Bronco HOW-TO DIY:  Bronco Door Caddie Holder w/ pictures/dimensions 20210906_171206
Ford Bronco HOW-TO DIY:  Bronco Door Caddie Holder w/ pictures/dimensions 20210906_171200
I brought one of the front doors into the shop to inspect it. You can see the bottom has rubber "feet" that are perfect for resting the door on:
Ford Bronco HOW-TO DIY:  Bronco Door Caddie Holder w/ pictures/dimensions 20210906_171242
The lip of the door is around 1.25", so a 2x4 is the perfect thickness (1.5)for the door to rest on without putting weight on the lip.
I made a frame 32" wide and 30" tall--tall enough to be slightly taller than the door when it reclines on the divider, and wide enough to be a sturdy platform for the door. Here it is mounted to the dolly.
Ford Bronco HOW-TO DIY:  Bronco Door Caddie Holder w/ pictures/dimensions 20210906_181742
To mount it, I flipped the dolly over and drilled holes for two bolts in the center of the dolly longways.
Ford Bronco HOW-TO DIY:  Bronco Door Caddie Holder w/ pictures/dimensions 20210906_173355
I then attached the frame to the dolly with bolts, lock washers and nuts.
I put a 2x4 cleat on each side for the door to rest on. I attached these with 2.5" drywall screws. I put carpet left over from remodeling on the divider and the plastic edging. I put 2x4's spaced with 1/2" particle board (which makes 2x4 width) at the top of the divider. Note the gap in the middle to allow the door lock "bump" to stick through:
Ford Bronco HOW-TO DIY:  Bronco Door Caddie Holder w/ pictures/dimensions 20210906_182306
The end result:
Ford Bronco HOW-TO DIY:  Bronco Door Caddie Holder w/ pictures/dimensions 20210906_182910
The bottom lip of the door does not touch...that was one goal (don't mind the dust on the door...that's what happens when you bring them in a wood shop...):
Ford Bronco HOW-TO DIY:  Bronco Door Caddie Holder w/ pictures/dimensions 20210906_175345
The other goal was to have it roll sturdily with no chance of flop over:
88to21bronco
88to21bronco
Tennessee
Great write up! I am making plans to do this as well.
But I was also looking at wall space to hang the doors on my garage walls...I got time though.
That's a good idea too... maybe that will be next.
BandofEskimoBrothers
Jay
Fort Mill, SC
This looks great! Any reason why there is no lip on the outside edge? Are you not worried about the bottom of the doors sliding out?
88to21bronco
88to21bronco
Tennessee
Ha! My wife was worried about the same thing!
1. There are rubber feet on the bottom of the door.
2. The angle is acute enough that it won't slide *hopefully*
3. The carpet acts as a sort of ledge.
It is super sturdy so far.
JAC
Joshua
Oregon
2018 Toyota Tundra; 2020 Acura RDX
Awesome work! link to post saved, will need this for mine (eventually).
