Hey, I install a tailgate (window) light bar and the power socket stay hot for 1 hour after vehicle is completely shut down. Just open any door to reset.Is it possible to have it power on full time?
And how to ?
And how to ?
It's possible but you'd have to bypass the relay in the battery junction box.
If you are asking if it is possible to do so without rewiring... then no, it is not possible.
It's not full time power? That sucks because that is how I run my fridge.
I know this forum is full of jeep haters, but in my wrangler, jeep did this cool fuse box thing. Depending on which slot you put the fuse in, you can go from Full time to only Ignition switch for the 12v accessory plugs.
My wife's Mazda is full time by default. So whenever we are shopping, using either the Mazda or my Wrangler, I can just toss the fridge in the back and we are good.
Works for me... no worries of a dead battery later. Lol
Just add jumper terminal clips (?) To the socket feed wires.
ForscanSo... get up every hour to open your car door to keep your refrigerator running. Sounds like a plan to me...
Coming from Jeep, the behavior of these 12v DC ports is very annoying. Jeeps have a 2-position fuse for the cargo 12v DC plug, so you can set it to be always on, or switched on/off with the ignition. This is very handy when running a 12v fridge on a lithium battery, as you can let the lithium battery power the fridge--let the lithium battery charge from the 12v DC cargo plug when the vehicle is running, but then your fridge battery stops pulling power from the vehicle battery when the ignition is cut off (and the fridge can then just run off the battery power).
The Ford algorithm for their power to the rear cargo 12v DC is kind of confusing. I feel like there should be a way to switch it to cut off with the ignition cut off. I get that their battery saver stuff will cut power to the port after a period of time, but I would rather not discharge the starting battery at all from my cargo area DC port...
Maybe I should just trust their battery saver tech... but it just feels odd to do that after so many years of being able to definitively cut the DC power with the ignition shut off.
Yup that's what I did in my Jeep, installed the ARB DC plug straight to the battery for when I wanted to run direct to it all the time. Feels like with Bronco this should be achievable in software, wish there was a setting for it in the dash.Funny.. I'm the opposite. I switched my fuse in the Jeep so that my cargo plug is powered 24/7. IF i decide to leave my fridge plugged in directly to the Jeep then it should never shut off (until the fridge low voltage kicks in)
Just a couple weekends ago, I had the Jeep shut off for a couple hours and left the fridge running on the Jeep battery... So I need to figure out a way to fix the Bronco to be permanent 12 volts (or at least until the battery drops below a certain voltage.
May end up having just to run a power wire directly from the battery to the back with a battery minder installed.
I am not seeing this in BCM on forscan.. just Power Point Feature which is enabled and Powerpoint Timeout set to 4500 - can u point me in the right direction?Forscan
BCM module of Powerpoint Timeout. Rear, console and cargo hot
