How can you install exterior lights for example those rigid lights in the accessory ready location next to the mirorrs (if you don’t have aux switches)?
Ask and ye shall receive.How can you install exterior lights for example those rigid lights in the accessory ready location next to the mirorrs (if you don’t have aux switches)?
With something like this. This is what @4x4TruckLEDs.com is using to run lights on his Bronco. Customizable and can mount anywhere you want.How can you install exterior lights for example those rigid lights in the accessory ready location next to the mirorrs (if you don’t have aux switches)?
As someone else pointed out, with an aftermarket switch panel. I like the AuxBeam. It's a cheap panel that does the job. It's also small. You can get much better quality with something like a Switch-Pros but those are what... like $700 or so. For $150 you can get a panel that works just as well.How can you install exterior lights for example those rigid lights in the accessory ready location next to the mirorrs (if you don’t have aux switches)?
