j_anderson
j_anderson
Fort Wayne, IN
www.instagram.com
ballkc41
Ken
Madison, MS
Bronco Black Diamond MT
I am in the middle of this project on a manual transmission Bronco (Black Diamond). The steps are very similar.
Pictures are how to remove the gear shift knob and the rear access to the console - so that wiring can be done without removing the console.
I will post more pictures once the epoxy dries.
Sherminiator
CNJ
2022 Ford Bronco Big Bend
I winded up getting one of the adaptors off Etsy-it’s a PLA 3D printed item. I could have printed one myself using one of my SLA printers, but had my doubts about how well the resin would handle heat wear and tear.
Anyways, one of the issues with 3D printed items are build build lines-it’s just way they work and they can be eliminated or reduced by orientation of the part.
I winded up sanding mine starting with some 320 grit and working my way up to 2200. I couldn’t get a decent shine on it so I went with plan B and broke out the plastic dip I got originally for my Bronco emblem(winded up replacing it with a black one) and sprayed it. Figured the rubberized finish would hold up well to abuse and match the interior pretty well too.
This is what it looks like before sanding.
Ford Bronco HOW TO: MagSafe Wireless Charger Install in Factory Location - DIY 726E2C1E-62DD-43BF-82FC-35F640EE0D13
I’ll post an after photo when I get everything installed.
Sherminiator
CNJ
Well haven’t gotten around to installing it yet due to weather being hot a hell, but here is a photo of the mount plastidipped and one of the skins that was linked in the first post.
Ford Bronco HOW TO: MagSafe Wireless Charger Install in Factory Location - DIY A4D5D47A-A31C-4161-886F-944BB4493416
Biz
Biz
Canada
21 OBX 2dr / 2019 Edge St / 2016 Focus RS
I have my prototype printed. Just need to pull the console to test fit the thing in the wife’s Bronco.
Sorry to revive an old thread but did you ever get this fitted and are you interested in selling the piece?
Thanks.
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Thanks.
I tried to do this with a piece I found on Etsy. It fits the charger perfectly and will work but when I went and took the console apart, it turns out that the OEM factory charger is the entire bottom of that well. I’d have to order a new console or make a false bottom to put in the new charger. If your vehicle doesn’t have a factory charger, then this solution is fine.
Biz
Biz
Canada
I have the lux package so was hoping this solution would work.
The factory charger is a hot mess.
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
schiesz
KC, MO
Jeep Wrangler
Mine is just quick and dirty from the 3d printer to bring the base of the compartment up to level with a cheap aftermarket Qi charger, plugged into the USB C port. Works well though.
Ford Bronco HOW TO: MagSafe Wireless Charger Install in Factory Location - DIY ghjk7157_n
604Bronco
British Columbia
www.bronco6g.com
Ford actually designed it to heat up your phone so much, it can be used as a hand warmer during the cold Winter months. Being a fellow Canadian, you should be thanking Ford for their innovation.
marjen
CT
I wonder what it would take to get chargers in these two locations on the dash.
Ford Bronco HOW TO: MagSafe Wireless Charger Install in Factory Location - DIY E61C0DAC-0BF4-4F16-9827-C4E9F5C6D06D
j_anderson
j_anderson
Fort Wayne, IN
www.instagram.com
I’m not sure you have enough space below those areas. I swapped that panel out for the lux panel and didn’t see empty space below there. However there is an opening under the center cubby. That is where the center speaker is in Lux.
The other issue is, you don’t really want your phone in direct sunlight.
j_anderson
j_anderson
Fort Wayne, IN
www.instagram.com
MannyG20
Ted
F-150
