How to read Pitch and Roll display / menu?
kylearmani
Kyle
Houston, Texas
GMC yukon denali
Hey all! I just got my bronco last month (finally after waiting nearly 2 years) and I would like to have a better understanding of the Pitch and Roll meter and how to properly read it (including what numbers should i look out for to indicate when the vehicle is pitching/rolling at a dangerous angle). Can anyone provide me with some tips?
Ford Bronco How to read Pitch and Roll display / menu? E09BFA86-D8A1-4DF6-BA87-E6F7755DAF92
Silver-Bolt
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
The upper gauge is the front to rear angle. Going downhill it will show your nose down and a - degree of angle. Uphill, nose up and a + degree of angle.
The lower gauge is the left and right angle.
Oldhippie
Barry
Santa Cruz, Calif.
I agree it is pretty useless without knowing when it will roll/flip. Tie a strap/winch to the “roll” bar and drive up something til both wheels come off the ground...then ya know.
R.A.N.M.J.
Rick
Top is Pitch.
It's read nose first. So, if your nose is point up at 45* it display that. Furthest I've had mine pitched forward was 51*. Scary business, that.
I made a helpful illustration:
Ford Bronco How to read Pitch and Roll display / menu? ohshit
Bottom is Roll.
It's read like a pendulum. The green line will demonstrate which direction your rolling into and the number will indicate the angle.
Things get dicey past 32* roll in a 2 Door Badlands. I know. From experience.
Edit: Shoot. Everyone got in and answered while I was making that work of art.
bikearch
Los Angeles Ca 91423
2014 camaro
Top is Pitch.
Bottom is Roll.
Stick people are my favorite people!
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
Your body is going to feel unsafe before the gauge hits any sort of number that you should be aware of.
Stampede.Offroad
SD
junk
Yeah, if you're moving slowly, you'll probably **** your pants before it rolls over. Unless you have some crazy load strapped to the roof.
AZMikeL
AZ
2022 Bronco Badlands 4dr, 2016 BMW 435i
I can attest that a stock 4dr Bad Lands will do a 30 degree roll without tipping over. It's somewhere past that when it goes over - unfortunately, that one time it did, I wasn't looking at the gauge as I had too much else going on :eek:
I had slipped off the main part of the trail into a rut/ditch and over she started to go. Thankfully, the roll stopped when the passenger rear view was only a couple of inches from the dirt and it reversed and rolled back onto the drivers side wheels. So, no harm done to the Bronco, but I can't say the same for pants!
All in all, regret saying "I don't need the locker for this" as it was rear wheel spin which caused the wheels to slip off the high part and into the ruts.
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
Offroadeo they said 30 degrees was the magic number if i remember correctly. Not the number at which point the Bronco rolls, because that’s different for every Bronco based on how it’s built and what weight it has etc…but the point at which fuel pumps, and oil etc can no longer maintain a suction and will fail. 🤷🏼‍♂️
Murfman
Colorado Springs
2021 WildTrak, Cyber Orange soft top
Some of the climbs and descents at Moab are 31*. As was stated before, with roll, you will feel you are going over long before you are actually getting there. With descents, remember, you always keep your wheels pointed in the direction down hill, that way you can drive out of it.
BigMeatsBronco
Allan
2021 FE 2 door
That seems like weak #s to me for a 7+ qt oil system. And of course the fuel pump is related to the amount of fuel on board. More than the angle itself. Even pulling a low .71 Gs on the skid pad, on flat ground, the oil will be at more than 30° angle ....just saying.
Mocopo
Kevin
Southern AZ
21 4dr Badsquatch. 22 JLUR-XR.
And if you start to tip forward, lay off the breaks... most people who tip forward its because they panic, hit the brakes, dig the front tires in, and over they go. Let it roll!!!
kylearmani
kylearmani
Kyle
Houston, Texas
GMC yukon denali
Top is Pitch.
Bottom is Roll.
Thank you for this man! The first day I got the car I went on a little “trail” in the neighborhood and got to 11* and got nervous😂 But I now I know everything is daunting when you are inside the car.
R.A.N.M.J.
Rick
You're welcome! I'm sure that photo-realistic depiction really snapped everything into focus. 💪🎨🥇
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
The one time I've had the opportunity to drive a Bronco (4-door), I got it up to a roll of 30°. Still felt stable, though my wife and back seat felt like she could just reach out the window and touch the ground.
