- Chris
- Mar 6, 2021
- 61
- 3,872
- 4,379
- Cold Spring, NY
- 2021 Bronco, 2020 Ranger
- Black Diamond
So interesting to me that the larger tire is suggesting lower PSI. Iāve already been running them around 36-37 due to comfort. Even after reading the disclaimer - it should make sense - but, my brain doesnāt comprehend.Just wanted to give an update that PCM relearn option worked for me today, and NO I did not download the latest version released 04/19/22, I used the previous version 2.3.46 released on 02/07/22, so I am not sure why but it did, it is worth a try, and if it doesn't then perform the PCM service reset function
Question for the experts here, If I ONLY
change the TPMS value in BdyCM but NOT the diameter, do I need to execute PCM and AWD relearn functions again to prevent a PCM 160A DTC??
I changed my tires to 295/70R18 so I increased the TPMS from 35 to 39 (mimicking sasquatch value) and my speedometer is spot on at 2600 circumference, but after checking tiresize.com/pressure-calculator/ it seems I should use the same 35 psi as my stock OBX tires.
Thanks
I should do the chalk test.
Is there any difference in changing the TPMS value? The warning doesnāt go off until itās in the high 20s.
