Remove the windshield header trim panel. Refer to Workshop Manual (WSM), Section 501-05.
Anyone know what this is exactly...
Same hereDepends on what you are trying to get to, I needed to access the hardtop panel striker plates and I was able to just remove the sun visor clips/stops and gently pull down on the trim and access the bolts. That's all I did.
Also, when I adjusted the strike plates to get the front panels even and a little lower the driver side had only the outboard 50 torx bolt tight, the inside bolt was about 1/4" from making contact with the plate. wth?Depends on what you are trying to get to, I needed to access the hardtop panel striker plates and I was able to just remove the sun visor clips/stops and gently pull down on the trim and access the bolts. That's all I did.
