Crazy? What part of this is Environmentally acceptable? Really surprised?Check out this guy’s story:
https://www.bronco6g.com/forum/thre...replacement-because-of-one-missing-clip.22729
Looks like the molding to the bracket broke wouldn’t be suprised if you**Thanks to a Forum member, found out "BestTop" NOT ACCURATE, 28 AUG WAS TOLD WEBASTO makes the soft top for Ford to assemble. Webasto doesn't sell to customers, must go through Ford. The part I broke is the Header Assembly, still need the Ford Part Number??? Help is appreciated!!
*18 Aug Updated pics*
**Really need Part number help from forum*
So just two weeks into ownership of my Bronco I broke the Soft Top!
The Broncos been great, from wading into the gulf extracting a Waverunner, to hauling luggage and passengers to and from the airport with ease, and swallowing a flatbed full Sam's club items it's cavernous cargo area!
In exchange for it's fantastic abilities and service I give my bronco a big thank you by smashing my soft top into my garage wall. I probably would have been better off had the bronco been safely held at the Michigan Assembly plant!
I wonder if there's a part number for just the composite panel at the hardware screws into?
Yes dealer confirms entire top. Bestop isn't selling theirs yet, I can't drive my bronco with 490 Mike's on it cause what I did to it, but bestop is still not ready for prime time. Unless your TFL!Looks like the molding to the bracket broke wouldn’t be suprised if you
Need a whole new top maybe just ditch the shitty webasto top amd get a bestop but they like 2000 I think
I was even thinking a fiberglass fabrication might work.Is there any chance you can glue this back together (for scanning purposes) and then have someone 3D scan and 3D print this out of composites? There are some pretty strong materials being used now for that. It would have to be a large format device, but have to believe this is possible - certainly for less than the price of a top and sooner I would think.
If it is just the portions where the screws are secured, I'd try to mod it by creating an insert or some means of securing the fasteners in a more solid material (like creating a metal block or sandwich it in there. From what I understand, none of this is exposed to the elements, but hidden under the fabric. If so, countersinking anchoring on the back side would not be an issue (I would think). Hope it helps.I was even thinking a fiberglass fabrication might work.
That sounds like a good thing! Jeeps OEM, Bestop, ships out replacement pieces for this part on the Wrangler, at least twice a day per Bedroom customer care in Colorado.Is there any chance you can glue this back together (for scanning purposes) and then have someone 3D scan and 3D print this out of composites? There are some pretty strong materials being used now for that. It would have to be a large format device, but have to believe this is possible - certainly for less than the price of a top and sooner I would think.
saw a woman do the same thing on a youtube channel I follow. Had the Bronco less than 2 weeks. She just bent hers a little, still functional.**Thanks to a Forum member, found out "BestTop" NOT ACCURATE, 28 AUG WAS TOLD WEBASTO makes the soft top for Ford to assemble. Webasto doesn't sell to customers, must go through Ford. The part I broke is the Header Assembly, still need the Ford Part Number??? Help is appreciated!!
You are exactly correct, I'm pretty handy, but will spend a huge amount of time planning before I add other materials, methods to ensure it's as close to original as possible.If it is just the portions where the screws are secured, I'd try to mod it by creating an insert or some means of securing the fasteners in a more solid material (like creating a metal block or sandwich it in there. From what I understand, none of this is exposed to the elements, but hidden under the fabric. If so, countersinking anchoring on the back side would not be an issue (I would think). Hope it helps.
That's a great idea! I work on Eglin Air Force Base where we literally fabricate missiles, and bombs Daily! We drop and test them to on the largest Base in the World that is Eglin.Kind of a crazy idea. If there are any polytechnic vocational schools in your area, you can reach out to them to see if they are up for a challenge. I recently visited the PolyTech school my son is interested in and they had some large 3D printers.
