- Jun 3, 2019
- 18
- 872
- 2,833
- Plymouth Michigan
- Website
- www.brokeninnovation.com
- 2021 Bronco Badlands non-sas 4 door manual
- Badlands
I appreciate the input, and I agree, that there is value to be gained using SFA with regard to maximum wheel size for sure! I will say though, that the number of joints is actually not that significantly increased. The control links for an axle have 8 joints (10 if its not triangulated, though that also reduces load), and the knuckle pivots (similar geometry to IFS knuckles afterall) add 4 more. So there's 12 Joints (or 14 if not triangulated), the IFS rig, at least SLA will also have 12, granted the knuckles have to handle another degree of freedom, the inner joints get to lose one degree of freedom. But I grant you that in typical package the loading of the SFA linkages can be straighter, though not in every case (always a but lol). And again I agree that its easier per dollar to make those same joints/linkages tougher on the SFA.You can bring up Ultra4, or Side by Sides all you wish, but those are completely different beasts in their setups. Ultra4 IFS suspensions have nearly zero in common with any production IFS, except the fact that they are IFS. Hell, their control arms are nearly as big around as the frame on an F-150 (ok, that may be a slight exaggeration, but you get the point). In 99% of use time/cases however, IFS is a better choice for a myriad of reasons. But for the same amount of beefiness (not even costs, just beefiness, same size joints, same thickness axles, same size bearings, etc), the SFA can hold either larger tires, or a more powerful engine, or both at the same time, than an IFS assembly.
Regarding IFS in Ultra-4 I think the similarity is no more ridonkulous than the SFA counterparts. Stock Wrangler does not have nearly the same size linkages both in length or heft (especially heft) and are also not triangulated. The axle itself which is necessary structure is also severely modified. You can argue that those mods are easier to do to a stock rig, but (again with the but) I think IFS is really not that difficult to swap parts on either. As far as hard points go, I think they can be made very stout in either case.
The harder thing for IFS to do is upgrade driveline and that is purely due to lack of supply. There isn't anything so inherently weak about and IFS diff/axles but right now you cant exactly just grab an upgrade off a bigger truck like you can with SFA.
In short, I think it again boils down to cost. But at the most extreme cases where you are running 40-50" tires SFA is the only way to go. Not because IFS cant but because who is going to jack the cradle down 3 ft just for tires lol.
