- First Name
- Brian
- Joined
- Jul 17, 2020
- Threads
- 6
- Messages
- 571
- Reaction score
- 808
- Location
- Northern Colorado
- Vehicle(s)
- 1966 Bronco, 2013 F-150
- Your Bronco Model
- Badlands
I recently installed the 4W Parts bumpers on my Badlands. I’ve absolutely loved the look of these bumpers since they first dropped. And as more and more bumper options became available, I found myself going back to the 4WP ones. So I finally pulled the trigger.
I had a ton of questions that I couldn’t find answers too. The sales reps didn’t know, the pictures on-line didn’t match the videos, the brochures in the store showed something different, and on-and-on. It’s a total cluster F**k. And even then, the instructions are totally junk and don’t answer questions either. So you learn as you go.
So to help anyone that’s curious, I figured I’d get on here, make a post and answer any questions ya’ll might have. I can even run out and take pictures as needed to help with answers as well.
A couple of the big questions I know I’ll get. So I’ll answer these now, because I know they’re coming. I’m also going to tag @Theherofails becaue he helped me install them and can chime in as necessary.
First - Yes, the ACC works. There’s nothing that needs to be done. It just works perfectly. Don’t worry about it. Zero issues.
Two - Yes, the camera is blocked by the winch and bull bar. I installed the JCR camera relocation kit and now visiblity is perfect. The blocked camera is not an issue.
Three - Parking sensors work great. The bumper gives you the option to run them, or if you don’t have them, there is plugs for the holes provided.
Four - With the Badlands SAS you do NOT need to buy the skid plate. The factory steel one works just fine with no modifications. Just bolt the stock one back up. I do not know about the plastic factory one.
Five - Lights The bumper allows you to run a bunch of different light configurations. Included 4 lights down in the middle bottom. (I ran 2). There’s also a separate little pieces to fill the gap if you don’t want to run lights, and want the bottom middle opening smaller.
Six - She’s heavy!!! This is not a 1 man job. We did it with 3 of us, which is what I recommend to anyone doing this job. It’s also an 8-10 hour day to install both bumpers and the winch. It’s a massive project.
Anything else, ask away and I’ll answer them.
Looks great.
Any sensor issues? I have an early one and had a lot of trouble.
Front bumper. If you mount the winch plate after the bumper, it's a mess.
The rear bolts are impossible to get to and torque. If you need to take the winch off, the whole bumper needs to come off.
On the rear bumper, were you able to get the end to line up with the body?
Tried my best but the two are angled differently.
Rear bumper install.
I ran my wiring through a drain plug and under the rear panneling.
https://www.4wheelparts.com/sku/4 Wheel Parts/standard/4WP61468W_Bronco_Rear_Bumper_20Jun21.pdf
