- Scott
- Mar 27, 2023
- 23
- 463
- 795
- Saratoga Springs NY
- Chevy LT Trail boss
- Badlands
Easiest way to figure out what size fuse you need for adding lights is simple using this method. Does not matter if you are running 1 light or 4 together.. Take the TOTAL wattage from all the lights your hooking up and divide it by Volts will equal the amps with is the fuse size you will need to run your aftermarket lights.. So watts Divided by volts (most batteries are 12.5-13.5 volts =amps- fuse size.. I always use 12.5 to figure out fuse size.. Hopefully this helps some of you out on installing your lights..
