I test drove lifted 2.3 Ranger w/35s and 2.7 F150
indio22
Chicagoland, USA
1972 Land Rover, 1985 CJ-7, 1998 TJ, 2014 BRZ
Vehicle Showcase
No automatic transmission on the planet adds 600 pounds to a vehicle. Unless you are toting an extra in the bed. Those weights are totally wrong. And since when can you get an F-150 with the 2.3L?
edit: I checked, you are wrong. Automatic adds 20 pounds. You are reading the spec sheet wrong. The approx. 600 lb weight difference is the entire 2-door Bronco model range spread. As in, stripped base all the way up to loaded out 'squatch. 4-door weight range is a little less of a spread, but still significant. Not sure how you can add 600 pounds to the truck with options but we don't really know how Ford got to that number. One could be with doors and roof removed and no options vs. a loaded truck with all doors and windows and loaded down with accessories like roof racks and winch for all we know.
Agreed - something seems amiss or not clearly accounted for with those vehicle weights. Leastways, I lifted on my own (with some effort) the 3 speed auto trans from my Wrangler into my van for a rebuild recently. And I'm no incredible Hulk. Hard to believe adding 7 more speeds to the Ford automatic would add 400+ lbs.
But if certain loaded configurations of the Bronco add potentially 600lbs, that can have some impact on acceleration/handling. Even when taking the hardtop off my Jeep, the acceleration and handling improves. Avoiding a lot of extra weight could help performance of the 2.3L.
Advertisement
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
2020 Jeep Wrangler, 2016 F150 Lariat
The 3.5 is fast. I currently have it in my F150 with 35s and a 2.5 level lift. I have beaten a standard 5.0 if with all of my 4 wheels engaged. I’m not sure I would want this in the Bronco. In rain, I have trouble not spinning my tires. Might be too much power for me. I plan on off-roading and overland mostly. Not going to race it.
I have also driven the 2.7. It will be the perfect fit for me. Plenty of power and fun.
Haulin455
Ford F-150
Uh what? You have trouble not spinning your tires in the rain? I have a 3.5EB in my F-150 and never have had that issue. Either you drive with traction control off in the rain and/or have an extremely heavy foot. With traction control on in the rain the tires might slip for a split second on harder acceleration from a stop but never to the point that they’re spinning. Unless whatever those 35” tires you bought are just bad in the rain and provide little grip.
Mainerunr
Justin
Maine
2015 F150
2020 Ford F-150 XLT 4WD SuperCrew 5.5' box w/ 2.3L - 4770 curb weight
Base Ford Bronco 2 door M/T with 2.3L - 4330 curb weight approx
Base Ford Bronco 2 door A/T with 2.3L - 4965 curb weight approx
Base Ford Bronco 4 door M/T with 2.3L - 4500 curb weight approx
Base Ford Bronco 4 door A/T with 2.3L - 5100 curb weight approx
No such thing as the F150 with the 2.3. No way going from a MT to an AT adds 600 lb either.
And that weight for an XLT 4x4 Supercrew 5.5' box cannot be right. I have one (with the V8 which, weighs about the same as the 2.7 EB) and the curb weight of my truck is 5182 lb.
And for anyone knocking the 2.7 EB because they want a V8, that V6 makes more low end torque than the Coyote so...the only thing you would gain with the V8 is the sound.
Mainerunr
Justin
Maine
2015 F150
Anybody with a 2.7 ecoboost f-150 knows it'll be no issue. i haven't been a sports car guy but my 2.7 f150 is the fastest vehicle i've ever owned. it hauls. balls. you can debate the decimal points but its something like a 6 second 0-60 on a full sized crew cab truck. i tow my 20' boat like its not even there. my gas mileage mixed always sits above 20mpg. the absolute shit would be a supercharged 3.5 ecoboost like they put in the limited and raptor. the limited is the second fastest production truck ever built, and moves that truck to 60 in 5.1 seconds.
The limited and Raptor do NOT have a supercharger. It's just a different 3.5 EB than in the regular F150s (few different parts, very different tune).
You are right about the 2.7 though. I have the V8 in mine, I drove both, the 2.7 was great, only issue was unless you got the payload package, the payload int he 2.7 trucks was no better than my 2011 V8 while the truck I got had 400lb more payload than my old one (and while I was nowhere near the tow rating with my old truck towing my TT, I was right at the payload limit).
rubikiller
Bryan
Houston
The 3.5 is not significantly faster that the 2.7 if at all
Jsullivan
Jay
2018 Explorer, 2016 F350 Diesel, 2013 Explorer
I had the 3.5 EB in a SC F150 4x4 8' bed completely stock and it absolutely would haul a$$.
I'm sure the 2.7 EB in my 2-Door Bronco will do just fine.
Advertisement
Holley (Ford Fest banner)
Advertisement
