IAG Roll Bar Paint Protection Film
bytheway
Brice
Louisville, KY
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Raise the top properly and it won't scrape! lol
Daktari
Oliver
I'm thinking more about putting some self adhesive felt strips on the parts of the roof that come close, if Ford doesn't do that already now. Or maybe both, PPF and felt. I'm not sure just the PPF would be enough if the bars make contact too often.
LSU Jonno
Huntsville, AL
2022 Bronco
Has anyone ordered/installed this? My Bronco is shipping this week and I want to get some coming for protection from the soft top frame. I just wonder how well it would hold up to a metal bracket scraping against it. Is it like a phone screen protector where it saves you once and you have to replace it?
https://www.iagperformance.com/iag-...ilm-kit-for-2021-ford-bronco-4-door-soft-top/
Ford Bronco IAG Roll Bar Paint Protection Film 1631557690694
You definitely need the film plus the felt. The soft top on my dealer demo had felt, my bronco at the Off-roadeo did not. Not sure if the felt was something my dealer added or if its standard now. However, I could still see a mark (not a scrape) where the felt was rubbing on the roll bar. So I think you want both layers of protection for now.
Bronco cat
Carl
Morgantown wv
‘20 Explorer ST, ‘19 GT350, ‘21 Bronco Sport
Better to be safe than sorry.
Amcap76
2018 F250, 2019 GT-350, 2004 Jeep LJ
I recommend everyone who plans on removing their hard top apply this.
Removing and replacing the hard top is like playing Operation. But, instead of a loud buzzer you scrape paint off the roll cage.
bytheway
bytheway
Brice
Louisville, KY
The best tip I saw was to open it from inside the car, step through to the back seat and close it from the center so you’re not pulling from one side or the other.
BostonGuy
Boston
Jetta
Does anyone have a picture of the felt and where it's located.
DubC
Houston, TX
instagram.com
2021 Bronco, 2016 F150, 2022 Highlander
Thanks for posting. Just ordered a set. StickerFab also posted his solution, but don't like how it was two pieces and not clear.
Daktari
Oliver
I was gonna use 3M PPF film, but since these are already cut to fit I just ordered a set. If there are no felt strips I'll get some myself too, once (if?) my Bronco shows up here.
bytheway
bytheway
Brice
Louisville, KY
Well I went ahead and ordered it too. Free UPS ground shipping sold me. Will post results after install.
bytheway
bytheway
Brice
Louisville, KY
Just asked a guy who got delivered last week if he had the felt added. Looks like the factory did update things
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
When you release the back to put the top up, it MUST click twice or the opposing side will lag and the twisting brings the supports closer together reducing the space between the support and sport bar, if you don’t, you WILL scratch!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I ordered these and they’re getting installed at the body shop after they finish up the work. I didn’t have scapes in the roll bar - but, the hardware was scraping against itself. Figure, better safe than sorry for $20.
Ford Bronco IAG Roll Bar Paint Protection Film 03B670C2-791B-4DB4-803D-E7F0EBBF915B
Ford Bronco IAG Roll Bar Paint Protection Film 6D3B8CD0-4988-460E-B4B0-503E83AB8D09
There was felt in certain spots when it delivered. Not sure if they are strategically placed for the roll bar or what. I haven’t inspected well enough. I will when I get it back from the dealer. I ordered more felt tape to reinforce where needed.
redone17
Cold Spring, NY
I knew I should have installed these myself…but, I opted for the free labor while it was in the body shop. Anyone else install these? Passenger side looks good. Driver side looks like a kindergartner cut them (see lower line). I didn’t unroll them prior to handing the package over - no idea why whoever installed them would have had to cut them if they were pre-cut to size.
Ford Bronco IAG Roll Bar Paint Protection Film 41FA8D28-80D3-4C21-AA99-3B5A0259C985
