IAG V2 Step Alternative Mounting Method
RoLyMa27
Rodney
SloKart, TX
21 Bronco, 22 Maverick
Our new IAG V2 steps arrived Wednesday. So, having the day off today I decided to go ahead and install them. At first I was having trouble installing them the way IAG intended, (they really restrict you in how you mount these) So, I had to think outside the box!
Here you see the high quality materials and impeccable workmanship. Although I'm not quite sure what the bracket/hook thingy's are for?
Ford Bronco IAG V2 Step Alternative Mounting Method PXL_20220415_134142003
In this photo you see the high strength adhesive step mounting hardware I used. I recommend Duck tape brand. Gorilla tape is an acceptable alternative.
Ford Bronco IAG V2 Step Alternative Mounting Method PXL_20220415_134111341.MP
Here you see the step fully installed. Note: you will need a helping hand in this process as it is difficult to apply the high strength adhesive while holding the step!
Ford Bronco IAG V2 Step Alternative Mounting Method PXL_20220415_133908086.MP
In this photo you can see the step actually protrudes a little past the fender flares. Ya'll think it's gonna hang on a rock if we take this thing to Moab?
Ford Bronco IAG V2 Step Alternative Mounting Method PXL_20220415_133918119.MP
Here you can see the stainless logo plate goes well with the silver paint.
Ford Bronco IAG V2 Step Alternative Mounting Method PXL_20220415_133926930
Here in this photo you see the step installed on an INFINITI Q50 rental car! Because.....
Ford Bronco IAG V2 Step Alternative Mounting Method PXL_20220415_134003149
This is the actual Bronco the step would be mounted to, at the body shop waiting on bumper brackets.
Ford Bronco IAG V2 Step Alternative Mounting Method PXL_20220411_182514672
I think this is worse than not having the Bronco at all.
