- Josh
- Apr 25, 2022
- 364
- 521
- 176
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
ICON 48400DJ Fits 2021-2022 Ford Bronco Tubular UCAs with Delta Joint PRO
Features: Built in added caster for better handling on lifted vehicles
Delta Joint PRO allows maximum articulation without binding
Delta Joint PRO is 100% serviceable and rebuildable
Serviceable dual stage pivot bushings
CNC machined housings for bushings and Delta Joint PRO
1026 DOM tube construction with black powder coat finish
Billet dust cap for Delta Joint PRO
Does Not Fit Ford Bronco Sport
The 2021-2022 Bronco ICON Tubular UCAs w/ Delta Joint PRO Allows for Maximum Travel for Performance Shocks and Coilovers ICON has been a leader in premium aftermarket suspension products for the 2021-2022 Ford Bronco. There newest line of products, the tubular suspension components, are designed to squeeze the most amount of off-road performance possible from your suspension. The 2021-2022 Bronco ICON Tubular UCAs w/ Delta Joint PRO are the control arm portion of this new line of products. These UCAs are designed to clear up some space in your front suspension to allow maximum travel for aftermarket performance shocks and coilovers. For those of you with lifted 2021-2022 Ford Broncos, there is additional caster built into them to make the front end alignment better. No matter what state your current off-road build is in, these are the UCAs for you. They are a serious upgrade from the factory units that are guaranteed to leave you in awe of your 2021-2022 Ford Bronco's new suspension capability.
Delta Joint PRO Provides Durability and Performance Improvement The all new Delta Joint Pro in the 2021-2022 Bronco ICON Tubular UCAs are a huge durability and performance improvement caveat that sets these UCAs way above those equipped with the standard Delta Joints. You will get 90 degrees of free articulation that gives you the ability to maximize your suspension travel without any binding. These Delta Joints PRO are larger than your average ball joints and full rebuildable so that you can complete any necessary work around them without them getting in the way. The included precision machined bushings at the frame pivots are also rebuildable and fully greasable. The Delta Joints PRO are guaranteed to last a long time with their premium anodized billet aluminum dust cap. This protection feature will keep your UCAs running properly and allow you to get the most out of them during your off-road excursions. The UCAs themselves are durably constructed from heavy wall DOM tubing that is CNC formed and fixture welded. For even more of a protective barrier, each UCA is finished with a multi-stage black powder coat. If you feel hesitant to invest into these UCAs and other ICON suspension components, you can feel more confident doing so knowing that you are covered by ICON's Limited
Lifetime Warranty.
Fitment:
2021-2022 2-Door Ford Bronco
2021-2022 4-Door Ford Bronco
Does Not Fit Ford Bronco Sport Note: Delta Joint PRO is covered by ICON’s 1-year warranty. Lifetime warranty does not cover bushings.
Lifetime Warranty.
Fitment:
