airishfan
rob
North Las Vegas
jeep cherokee
2021 Badlands -Non-Sasquatch - Not Lifted
Icon Rebound Pro
21817858347SB17x8.50"6x5.54.750"0mm106.10mm3200 lbs32 lbsSATIN BLACK
Nitto Ridge Grappler 35x12.50R17LT E 121Q
looking to get the same tires and wheels but maybe in Bronze but what did the wheels and tires end up costing you.
Dusty at ICON
Dusty at ICON
Dusty
Riverside, CA
2021 Bronco Base 2-Door
So today I looked at Icons website and it says that your Bronco has the +25?
Is that correct? Even with the standard flares in the pictures it looks like the wheels stick out pretty far. more like a zero offset.Unless it’s just an illusion? Because I was thinking about getting the +25 for my BaseSquatch and going with Nitto ridge grappler to push the tire out a little bit because I don’t like the narrow 9.5 tread of the stock Sasquatch wranglers.
I can’t find the specs of the actual tread width on a 315/70 ridge grappler? Section 12.7 but not tread. I know it’s a hell of a lot wider than the wranglers.
Thoughts thanks
I am interested in the compression in a +25 or zero
Yeah mine are +25, unless they pulled a fast one on me LOL. So they stick out about a 1/4" farther than the Sasquatch wheels, which are +30mm. Remember, my Bronco has standard flares so both the Sasquatch wheels and the +25mm Rebound Pros have some significant poke. I did actually have the Sasquatch wheels on mine for a short time so I looked for a pair of photos that were similar, to compare the two. These aren't the best angle for judging poke but you can sort of get an idea.
OE Sasquatch wheels 17X8.5 +30mm and tires 315/70R17 on a Base 2-Door Bronco with standard flares (non-Sasquatch) and 3/2 level-lift:
Rebound Pros 17X8.5 +25mm with 35X12.50R17 Nitto Trail Grapplers on the same Bronco:
I guess I really do need to start taking more pictures on level ground and in parking lots and driveways LOL.
Aguelian
Ashley
Infiniti Q50
Hey folks I thought it might be helpful to list all of ICON's Bronco-compatible wheels in one place. Here is every wheel that ICON currently offers that fits the 2021+ Ford Bronco. New styles, sizes and offsets are introduced regularly so I'll try to keep this list updated. Some notes:
  • FINISH: The finishes (colors) are listed in the table in the same order they are shown in the images (left-to-right).
  • OFFSET: Factory Sasquatch wheels are 17 X 8.5 with 30mm offset. ICON wheels with 25mm offset will put the outside of the wheel about 1/4" wider than the Sasquatch wheel. The ICON 0mm offset wheels will place the outside of the tire approximately 1-1/4" wider than the Sasquatch wheel.
  • HUB BORE: All of the wheels listed here will fit and work correctly with your Bronco's hubs. The Hub Bore column simply denotes which part numbers will be hub-centric (93.1mm bore) and which will be lug-centric (anything larger) in the way they attach and center onto the hub. If you're not familiar with those terms, don't worry, it won't affect fitment or function, either mounting method works fine.
  • PART NUMBERS are included so you may inquire directly with your favorite Authorized ICON Dealer with a specific part number in hand when checking price and availability.
  • This list includes ICON's 17" wheels only, at this time. I will update it soon with 18" and 20" Bronco-compatible part numbers.
REBOUND PRO 17 X 8.5
With patented InnerLock Bead Retention Technology - More Info in This Thread
FINISHBACKSPACEOFFSETHUB BORELOAD RATINGPART #
SAT BLACK4.75"0mm106.1mm3200 LBS21817858347SB
BRONZE4.75"0mm106.1mm3200 LBS21817858347BR
TITANIUM4.75"0mm106.1mm3200 LBS21817858347TT
SAT BLACK5.75"25mm93.1mm3200 LBS21817858357SB*
BRONZE5.75"25mm93.1mm3200 LBS21817858357BR*
TITANIUM5.75"25mm93.1mm3200 LBS21817858357TT*
*Not yet available to order directly from ICON but may be ordered through most ICON Dealers (you may have to contact them to order, as these might not be added to their websites yet).
REBOUND 17 X 8.5
SAT BLACK4.75"0mm106.1mm2750 LBS1817858347SB
BRONZE4.75"0mm106.1mm2750 LBS1817858347BR
TITANIUM4.75"0mm106.1mm2750 LBS1817858347TT
SAT BLACK5.75"25mm93.1mm2750 LBS1817858357SB
BRONZE5.75"25mm93.1mm2750 LBS1817858357BR
TITANIUM5.75"25mm93.1mm2750 LBS1817858357TT
COMPRESSION 17 X 8.5
SAT BLACK4.75"0mm106.1mm2750 LBS2017858347SB
BRONZE4.75"0mm106.1mm2750 LBS2017858347BR
TITANIUM4.75"0mm106.1mm2750 LBS2017858347TT
SAT BLACK5.75"25mm93.1mm2750 LBS2017858357SB
BRONZE5.75"25mm93.1mm2750 LBS2017858357BR
TITANIUM5.75"25mm93.1mm2750 LBS2017858357TT
VECTOR 6 17 X 8.5
SAT BLACK4.75"0mm106.1mm2750 LBS2417858347SB
BRONZE4.75"0mm106.1mm2750 LBS2417858347BR
TITANIUM4.75"0mm106.1mm2750 LBS2417858347TT
SAT BLACK5.75"25mm93.1mm2750 LBS2417858357SB
BRONZE5.75"25mm93.1mm2750 LBS2417858357BR
TITANIUM5.75"25mm93.1mm2750 LBS2417858357TT
ALPHA 17 X 8.5
SAT BLACK4.75"0mm106.1mm2500 LBS1217858347SB
GUN METAL4.75"0mm106.1mm2500 LBS1217858347GM
BRONZE4.75"0mm106.1mm2500 LBS1217858347BR
TITANIUM4.75"0mm106.1mm2500 LBS1217858347TT
SAT BLK/MACHINED4.75"0mm106.1mm2500 LBS1217858347MB
SIX SPEED 17 X 8.5
SAT BLACK4.75"0mm108mm2500 LBS1417858347SB
GUN METAL4.75"0mm108mm2500 LBS1417858347GM
BRONZE4.75"0mm108mm2500 LBS1417858347BR
TITANIUM4.75"0mm108mm2500 LBS1417858347TT
SAT BLK/MACH4.75"0mm108mm2500 LBS1417858347MB
SAT BLACK5.75"25mm108.1mm2500 LBS1417858357SB
BRONZE5.75"25mm108.1mm2500 LBS1417858357BR
TITANIUM5.75"25mm108.1mm2500 LBS1417858357TT
THRUST 17 X 8.5
SAT BLACK4.75"0mm106.1mm2750 LBS2817858347SB
SMK SAT BLACK4.75"0mm106.1mm2750 LBS2817858347SSBT
SAT BLACK5.75"25mm93.1mm3200 LBS2817858357SB
SMK SAT BLACK5.75"25mm93.1mm3200 LBS2817858357SSBT
COMPASS 17 X 8.5
SAT BLACK4.75"0mm106.1mm2750 LBS3217858347SB
SAT BRASS4.75"0mm106.1mm2750 LBS3217858347BS
RAIDER 17 X 8.5
SAT BLACK4.75"0mm106.1mm2750 LBS3417858347SB
SAT BRASS4.75"0mm106.1mm2750 LBS3417858347BS
TITANIUM4.75"0mm106.1mm2750 LBS3417858347TT
VICTORY 17 X 8.5
SMK SAT BLACK4.75"0mm106.1mm2750 LBS3017858347SBT
SAT BLACK RED4.75"0mm106.1mm2750 LBS3017858347SBRT
Hello, do you know which offset is in this pic?
T1B
Zach
SoCal
2016 Tundra CrewMax (overland build)
Whats the status with a 0mm wheel on a sas? Any rubbing at all? Stock tires, stock everything else. Will it rub? Can I have full articulation? What about city driving like driveways, reverse and turning etc. Cheers!
Rolandfj40
Dirty Jersey
2dr FE, Camry
So are there any Area 51 broncos riding on rebounds that aren't black? I'd love to see pics thx.
bstottlemyer85
Ben
Clarksburg, West Virginia
instagram.com
GMC
What I paid for the the whole set up:
Icon - Sun StoppersRebound Pro 17x9 0mm ($320x5)$1,600.00
Nitto - Sun StoppersRidge Grappler 35/12.50/17 ($336 x5)$1,680.00
- Sun StoppersTPMS Sensors (x5)$187.00
Lug Nuts (x5 sets)$50.00
Total: $3,517
ryannshit
Ryan
Castro Valley, CA
2021 Bronco Badlands 2.3 L Manual
Icon Rebound Pro
Just ordered the same tires and wheels but with the bronze Rebounds for my Badlands.
You didn't need to install a lift or leveling kit?
How about a tire reinforcement for the spare in the back?
Any chance you have a pic of your beast from the front?
Apologies in advance for all the questions :)
Dusty at ICON
Dusty at ICON
Dusty
Riverside, CA
Here are some nice shots of a Carbonized Gray 4-door on ICON Alloys Six Speed wheels in bronze. Thanks to our friends at Joe’s House of Speed for the pics.
Aguelian
Ashley
Infiniti Q50
Aguelian
Ashley
Infiniti Q50
Slyder
East Wenatchee, Washington
2014 KTM 1290R
I hope someone puts one of Icon's bronze and titanium colored wheels on a Hot Pepper Red to see if it compliments it or looks a bit out of place. I plan on Icon wheels, once/if the Bronco ever gets built, and would prefer to not get black.
(Bronze wheels come in enough different shades that not all look good against some vehicle colors)
Dusty at ICON
Dusty at ICON
Dusty
Riverside, CA
I have seen one photo of a 4-door in Rapid Red (I think, it might be Race red but it's shot in low light so not exactly sure) with our Rebound PROs in bronze, and it looks really good. It was posted in the Bronco B.A.B.E.S. Facebook Group. I have messaged the poster to ask permission to use her photo. If she grants it I'll copy it here. If you are a member of that group you could look for it there.
ryannshit
Ryan
Castro Valley, CA
I ordered the rebounds in bronze for my wrapped matte green Badlands.. nervous to see how it will turn out and they won't arrive for a few weeks.
If there are any Eruption green pics anywhere out there with bronze icons let me know! Think it will give me a decent idea.
