- First Name
- Dusty
- Joined
- Oct 4, 2021
- Threads
- 18
- Messages
- 394
- Reaction score
- 1,275
- Location
- Riverside, CA
- Vehicle(s)
- 2021 Bronco Base 2-Door
- Your Bronco Model
- Base
- Thread starter
- #1
Hey folks I thought it might be helpful to list all of ICON's Bronco-compatible wheels in one place. Here is every wheel that ICON currently offers that fits the 2021+ Ford Bronco. New styles, sizes and offsets are introduced regularly so I'll try to keep this list updated. Some notes:
With patented InnerLock Bead Retention Technology - More Info in This Thread
REBOUND SLX 17 X 8.5
REBOUND 17 X 8.5
COMPRESSION 17 X 8.5
VECTOR 6 17 X 8.5
ALPHA 17 X 8.5
SIX SPEED 17 X 8.5
THRUST 17 X 8.5
COMPASS 17 X 8.5
RAIDER 17 X 8.5
VICTORY 17 X 8.5
- FINISH: The finishes (colors) are listed in the table in the same order they are shown in the images (left-to-right).
- OFFSET: Factory Sasquatch wheels are 17 X 8.5 with 30mm offset. ICON wheels with 25mm offset will put the outside of the wheel about 1/4" wider than the Sasquatch wheel. The ICON 0mm offset wheels will place the outside of the tire approximately 1-1/4" wider than the Sasquatch wheel.
- HUB BORE: All of the wheels listed here will fit and work correctly with your Bronco's hubs. The Hub Bore column simply denotes which part numbers will be hub-centric (93.1mm bore) and which will be lug-centric (anything larger) in the way they attach and center onto the hub. If you're not familiar with those terms, don't worry, it won't affect fitment or function, either mounting method works fine.
- PART NUMBERS are included so you may inquire directly with your favorite Authorized ICON Dealer with a specific part number in hand when checking price and availability.
- This list includes ICON's 17" wheels only, at this time. I will update it soon with 18" and 20" Bronco-compatible part numbers.
FINISH | BACKSPACE | OFFSET | HUB BORE | LOAD RATING | PART # |
SAT BLACK | 4.75" | 0mm | 106.1mm | 3200 LBS | 21817858347SB |
BRONZE | 4.75" | 0mm | 106.1mm | 3200 LBS | 21817858347BR |
TITANIUM | 4.75" | 0mm | 106.1mm | 3200 LBS | 21817858347TT |
SAT BLACK | 5.75" | 25mm | 95.1mm | 3200 LBS | 21817859057SB |
BRONZE | 5.75" | 25mm | 95.1mm | 3200 LBS | 21817859057BR |
TITANIUM | 5.75" | 25mm | 95.1mm | 3200 LBS | 21817859057TT |
SATIN BLACK | 4.75" | 0mm | 106.1mm | 3200 LBS | 1917858347SB |
CHARCOAL | 4.75" | 0mm | 106.1mm | 3200 LBS | 1917858347CH |
SATIN BLACK | 5.75" | 25mm | 95.1mm | 3200 LBS | 1917859057SB |
CHARCOAL | 5.75" | 25mm | 95.1mm | 3200 LBS | 1917859057CH |
REBOUND 17 X 8.5
SAT BLACK | 4.75" | 0mm | 106.1mm | 2750 LBS | 1817858347SB |
BRONZE | 4.75" | 0mm | 106.1mm | 2750 LBS | 1817858347BR |
TITANIUM | 4.75" | 0mm | 106.1mm | 2750 LBS | 1817858347TT |
SAT BLACK | 5.75" | 25mm | 93.1mm | 2750 LBS | 1817858357SB |
BRONZE | 5.75" | 25mm | 93.1mm | 2750 LBS | 1817858357BR |
TITANIUM | 5.75" | 25mm | 93.1mm | 2750 LBS | 1817858357TT |
SAT BLACK | 4.75" | 0mm | 106.1mm | 2750 LBS | 2017858347SB |
BRONZE | 4.75" | 0mm | 106.1mm | 2750 LBS | 2017858347BR |
TITANIUM | 4.75" | 0mm | 106.1mm | 2750 LBS | 2017858347TT |
SAT BLACK | 5.75" | 25mm | 93.1mm | 2750 LBS | 2017858357SB |
BRONZE | 5.75" | 25mm | 93.1mm | 2750 LBS | 2017858357BR |
TITANIUM | 5.75" | 25mm | 93.1mm | 2750 LBS | 2017858357TT |
VECTOR 6 17 X 8.5
SAT BLACK | 4.75" | 0mm | 106.1mm | 2750 LBS | 2417858347SB |
BRONZE | 4.75" | 0mm | 106.1mm | 2750 LBS | 2417858347BR |
TITANIUM | 4.75" | 0mm | 106.1mm | 2750 LBS | 2417858347TT |
SAT BLACK | 5.75" | 25mm | 93.1mm | 2750 LBS | 2417858357SB |
BRONZE | 5.75" | 25mm | 93.1mm | 2750 LBS | 2417858357BR |
TITANIUM | 5.75" | 25mm | 93.1mm | 2750 LBS | 2417858357TT |
ALPHA 17 X 8.5
SAT BLACK | 4.75" | 0mm | 106.1mm | 2500 LBS | 1217858347SB |
GUN METAL | 4.75" | 0mm | 106.1mm | 2500 LBS | 1217858347GM |
BRONZE | 4.75" | 0mm | 106.1mm | 2500 LBS | 1217858347BR |
TITANIUM | 4.75" | 0mm | 106.1mm | 2500 LBS | 1217858347TT |
SAT BLK/MACHINED | 4.75" | 0mm | 106.1mm | 2500 LBS | 1217858347MB |
SIX SPEED 17 X 8.5
SAT BLACK | 4.75" | 0mm | 108mm | 2500 LBS | 1417858347SB |
GUN METAL | 4.75" | 0mm | 108mm | 2500 LBS | 1417858347GM |
BRONZE | 4.75" | 0mm | 108mm | 2500 LBS | 1417858347BR |
TITANIUM | 4.75" | 0mm | 108mm | 2500 LBS | 1417858347TT |
SAT BLK/MACH | 4.75" | 0mm | 108mm | 2500 LBS | 1417858347MB |
SAT BLACK | 5.75" | 25mm | 108.1mm | 2500 LBS | 1417858357SB |
BRONZE | 5.75" | 25mm | 108.1mm | 2500 LBS | 1417858357BR |
TITANIUM | 5.75" | 25mm | 108.1mm | 2500 LBS | 1417858357TT |
THRUST 17 X 8.5
SAT BLACK | 4.75" | 0mm | 106.1mm | 2750 LBS | 2817858347SB |
SMK SAT BLACK | 4.75" | 0mm | 106.1mm | 2750 LBS | 2817858347SSBT |
SAT BLACK | 5.75" | 25mm | 93.1mm | 3200 LBS | 2817858357SB |
SMK SAT BLACK | 5.75" | 25mm | 93.1mm | 3200 LBS | 2817858357SSBT |
COMPASS 17 X 8.5
SAT BLACK | 4.75" | 0mm | 106.1mm | 2750 LBS | 3217858347SB |
SAT BRASS | 4.75" | 0mm | 106.1mm | 2750 LBS | 3217858347BS |
RAIDER 17 X 8.5
SAT BLACK | 4.75" | 0mm | 106.1mm | 2750 LBS | 3417858347SB |
SAT BRASS | 4.75" | 0mm | 106.1mm | 2750 LBS | 3417858347BS |
TITANIUM | 4.75" | 0mm | 106.1mm | 2750 LBS | 3417858347TT |
VICTORY 17 X 8.5
SMK SAT BLACK | 4.75" | 0mm | 106.1mm | 2750 LBS | 3017858347SBT |
SAT BLACK RED | 4.75" | 0mm | 106.1mm | 2750 LBS | 3017858347SBRT |
