ICON Billet Front UCA's & Rear Links
Dusty at ICON
Dusty
Riverside, CA
2021 Bronco Base 2-Door
Hey guys ICON's billet Front UCA's and rear Upper and Lower Suspension Links have been announced to our dealer network. Here's the low-down:
ICON 21-up Bronco Billet Front Upper Control Arms
Ford Bronco ICON Billet Front UCA's & Rear Links 1028211352
Improve your Bronco’s suspension performance with ICON’s Billet Upper Control Arms. Ford designed the new Bronco with great off-road capability right out of the box, but we just couldn’t help squeezing even more performance out of it. These billet UCA’s free up movement to allow maximum travel for performance shocks and coilovers.
Ford Bronco ICON Billet Front UCA's & Rear Links 48500DJ-Bronco_Billet UCA_STRT
The all new Delta JOINT PRO provides a host of durability and performance improvements compared to our standard ball joints and uni-balls, including up to 90° of free articulation to maximize suspension travel without bind. It’s also beefier and fully rebuildable.
Ford Bronco ICON Billet Front UCA's & Rear Links DJ-Pro-ArticulationGraphic5
Heavy Duty FK Rod Ends at the chassis pivots provide precise handling with smooth, tension-free movement compared to bushings. ICON’s proprietary Rod End Adjuster Sleeves allow for easy, precise adjustment of caster and camber, right on the vehicle. This is essential for fine-tuning your suspension after any lift or other adjustments.
Ford Bronco ICON Billet Front UCA's & Rear Links 48500DJ-Bronco_Billet UCA_SINGLE_3QTR
ICON Billet Upper Control Arms are CNC machined from 6061 billet aluminum with a satin anodized finish. The hybrid H-beam cross-section is light-weight resists bending forces better than tubular arms.
Hit the trail with the confidence of knowing your suspension components are covered by ICON’s Limited Lifetime Warranty*.
*Lifetime Warranty covers arms and components except: Delta Joint PRO is covered by ICON’s 1-year warranty on rebuildable joints. FK Rod Ends are covered by the manufacturer’s warranty.
At the time of this writing, these are not even on our website yet, so I can't include a link (I'll update this post when I have one). But several of our dealers have already listed them and are taking pre-orders, so check with your favorite ICON dealer!
NOTE: ICON is working on a full line of long travel performance shocks and coilovers for Bronco, which these arms will be featured in our multi-stage complete suspension kits. We'll also be doing tubular versions of our arms. I'll post about all of these here on the forum as the info becomes available :)
Dusty at ICON
Dusty at ICON
Dusty
Riverside, CA
ICON 21-Up Bronco Rear Upper & Lower Suspension Links
Ford Bronco ICON Billet Front UCA's & Rear Links e0e7f91c-ee5d-14e7-945b-b79745d11697
The ICON Billet Rear Link System helps free up rear axle movement on your 2021 and newer Ford Bronco to allow for increased suspension travel and articulation. Upgrading the links is essential to realizing the full benefits of ICON’s long travel coilover suspension system for the Bronco (coming soon).
Ford Bronco ICON Billet Front UCA's & Rear Links 44000_Bronco_Rear LowerLinks_PAIR_3QTR2_web_large
A Massive FK Rod End at one end, along with a dual-durometer, high angle greaseless bushing at the other end yields the best combination of maximum travel and articulation while isolating and damping road noise and vibrations.
Ford Bronco ICON Billet Front UCA's & Rear Links 44000_Bronco_Rear LowerLinks_SINGLE_CU._high_res
ICON’s proprietary “on vehicle” Adjuster Sleeve allows for fast, easy adjustment of Link length without requiring removal or disassembly of the Link. This allows for easy correction of axle location and pinion angle whenever adjustments are made to ride height.
Ford Bronco ICON Billet Front UCA's & Rear Links 44100_Bronco_Rear_UpperLinks_PAIR_3QTR2_high_res
Each Link is CNC machined from 6061 billet aluminum with an anodized finish. The hybrid H-beam cross-section resists bending forces better than round rod and tubular links. Hit the trail with the confidence of knowing your suspension components are covered by ICON’s Limited Lifetime Warranty*.
*Lifetime warranty does not cover rod ends and bushings, which are a consumable.
Ford Bronco ICON Billet Front UCA's & Rear Links IMG_0731
For more info see the ICON Website (Upper Links | Lower Links) or your favorite ICON Dealer!
Cybindustries1904
Tony
Discovery bay
23 Raptor, Mach E GT
take my money
Slyder
Washington
2014 KTM 1290R
The billet stuff sure is pretty. (I'm a cnc machinist for a living)
I'm anxiously waiting on the staged kits so as to help me decide on whether I want to drop Sasquatch package off of my 2-Dr Badlands order.
Dusty at ICON
Dusty at ICON
Dusty
Riverside, CA
Full disclaimer: all of the "knocked out" part images above are 3D renderings. But yeah the real deals are pretty too :cool:
