- Dusty
- Oct 4, 2021
- 18
- 394
- 1,274
- Riverside, CA
- 2021 Bronco Base 2-Door
- Base
- #31
This is the first product that gets the new Delta Joint PRO. We already had it in development for our F150 Raptor kits, but these Bronco UCA's have made it to market first. While we've had great results out of our original Delta Joint, the PRO was designed to provide the increased articulation the Raptor arms would need, and we took the opportunity to beef it up and make several other improvements as well, such as making it fully rebuildable, with replaceable bearing races. When we figured out the geometry on the Bronco suspension we determined that it could also benefit from the improvements to the Delta Joint Pro.Everything looks awesome. Has the Delta Joint PRO been used in any other applications or is this the 1st time? Really like the Delta Joint vs. uniball products that are available.
Also, in case some were wondering, I found out yesterday that both our billet and tubular UCA's will fit with stock Sasquatch wheels and tires, also with our 25mm offset Rebound Pros with 35" tires. With 37's on Sasquatch wheels or 25mm Rebound Pros, the tubular arms clear but not the billet ones. So the billet will want our 0 offset Rebound Pros to run 37's.
