Icon Vehicle Dynamics Bronco Build at SEMA 2021
Silver-Bolt
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
I have been telling you guys that the good stuff is coming. Well, it is arriving. Icon should tighten the jam nut on the rear lower control arm. lol
Hey19
JJ
Bethlehem
That looks like an adjustment for setting the arm length. The two bolts on top appear to be "pinch" bolts that would secure the assembly from moving. I could be wrong though.
At any rate, It looks like nice stuff.
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
ICOn has some of the smoothest riding springs and shocks in the Jeep world... im interested to see how thier coil overs for the Bronco Ride. They do build some nice stuff. They have thier own Bumpers and Wheels on it as well.
Dusty at ICON
Dusty
Riverside, CA
2021 Bronco Base 2-Door
@Hey19 is right. It's an adjuster sleeve, tightened by the two pinch bolts. It's a pretty slick setup. You can make small adjustments to the overall length of the control arm by turning that sleeve. That adjustability can be useful in a coilover setup that can be set up at a range of lift heights. You would adjust that control arm length to dial in the pinion angle, if you end up adjusting the ride height higher or lower. And yes they get mistaken for a loose jam nut all the time LOL
Dusty at ICON
Dusty
Riverside, CA
Thanks! Yeah we're still dialing these in for optimal ride and performance. The rear coils are a triple-rate spring, but we are still fine tuning the spring rates on it. But the coolest thing about this Bronco is that the shocks on it use our new CDEV technology, electronic valves controlled by a central processor that makes valving adjustments in real time, on the fly, automatically, for whatever the terrain conditions. It has a companion app for your phone where you can make adjustments, monitor shock performance, log data, etc. BTW they'll also be available with our non-electronic CDCV adjustable valves.
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
Awesome. Thanks for the info...
corey07
Oregon
F150 FX4
Great update, Thanks! Really looking forward to final release info.
wanna1
Andrew
2013 Ford F150 Platinum 4x4 2022 Mach E
I need this to go with your Rebound Pro wheels !!!
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
All those spacer lifts coming back off now.
Tonka Bronka
Duncansville
Cool. When can we see a parts list, what it will do, and the cost?
Dusty at ICON
Dusty
Riverside, CA
