Is it under 3500lbs? Then yes.I need some opinions on the 2.3 with SAS Pkg being enough to pull a 17 foot bow rider boat. Enough power????
Thank you for the input. Yes it is under 3,500 lbs. I have to pull it over a mountain and just wanted to be sure. I have a 2002 chevy silverado with a 5.3 with over 200 thousand miles on it and it does ok but lacks some power with the mileage. Thanks again.Is it under 3500lbs? Then yes.
Can we also add “white roof” into this? Enough. You didn’t get the white roof. Leave it alone.
Also includes questions about reliability, ecoboom and direct injection
It'll quickly turn into this:Can we also add “white roof” into this? Enough. You didn’t get the white roof. Leave it alone.
You're also talking about a diesel which has significantly more torque then a gas motor. I do believe the 2.3 will be enough, especially after some upgrades and a tune but I can't compare a diesel to a gasser.I had a Colorado ZR2 Diesel, and all of its 180 HP managed to move that 4700 pound mass along just fine on the highway, merging or cruising. I'm not quite sure why all of a sudden the 2.3L is not sufficient enough to get the Bronco up to speed.
^^^ this guy gets itThen you'd be making money in a very weird way.
I'm thinking get the 2.3L now and if it blows up down the road then swap in a built 2.3L and get around that 500HP mark without worry. Maybe that will cost more then $3500 but I will have peace of mind beating on it.I have had my exchanges with Rick A a few times, but then again we both like turning wrenches. I am most likely getting the 2.7. Someone mentioned the $3500 cost for the 2.7 and I got to thinking if I got the 2.3 which has plenty of power and it failed with some mileage I can probably pick up another one from a wrecked stang or Bronco and spend a day or two and swap it out for less than the $3500. Hmmmm....
I rented a 2021 jl wrangler Sahara for a week in South Florida (Miami area). It had a 4 cylinder and I was surprised by it. It was able to keep up on the interstate 70-80 no problem. This was the first 4 cylinder I drove in over 20years. I was shocked by the high pitch sound the engine makes. I got used to it.Off road or on back roads I am sure the 2.3 will be way more than adequate. I worry more about on road driving- blending into very fast moving traffic or making a lane change into speeding traffic to make a turn a mile ahead, etc. Very many straight, flat roads here in FL where traffic moves very fast- 70 MPH+. I frequently have to accelerate to 90 or 100 to merge in and not get get run over. Even in my 2016 Camaro (V6 with 6 speed) I have to mash it hard and people are still tailgating me. (and that car is no slouch). When I drive my 97 TJ it's like I am a sitting duck and it just won't go any faster......(I love my TJ other than for this reason). So if I have the 2.3 and manual and have to downshift at 60 or 70 to accelerate, will it be enough?
Well, the 2.7 will last longer than a 2.3. No doubt, but there will be blind nay-sayers. Nonetheless, I want to add the sure numbers of the 2.3 will make easy to pick up cheap.I'm thinking get the 2.3L now and if it blows up down the road then swap in a built 2.3L and get around that 500HP mark without worry. Maybe that will cost more then $3500 but I will have peace of mind beating on it.
