I'm looking for a flagpole mount to mount on the tailgate! Can someone help me?
OWEN
Rowlands Heights
FORD BRONCO
I purchased a folded flag:
handyflag
the bracket I bought before was only half an inch:
Trail Sight Accessory Mount
and I was worried about the risk of increasing the hole spacing at high speeds,It needs a bracket base with 1 inch holes
Someone with the same needs as me should be looking for it, and I'm sure someone is working on it!
I checked a lot of solutions on google, there are brackets on the front bumper, and there are brackets in front of the hood and windshield. In addition to the insufficient hole spacing, I am more worried that the flag is not safe enough to install in the front of the car, At the same time, I also think that it is more beautiful to install in the rear.
Similar to this:
EAG CB Antenna and Flag Whip Rear Tailgate Mounting Bracket Fit for 18-22 Wrangler JL with OE Tire Carrier
Tailgate Hinge Mounted Flag & Antenna Holder Kit Fit Jeep Wrangler JL 2018-2022
Advertisement
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
2021 AMB Bronco, 2021 CO Bronco
I have the tailgate mounted flag mount. Not sure how that would attach. The CB bracket is smaller.
BroncoJoerg
Joerg
Saugus, CA
Velocity Blue Badlands
I have the same mount. My question is, how do you connect the antenna to that small plate with the round hole in it? What parts would you need?
Hkak45
Harold K
Illinois
21 Bronco Black Diamond
Couldn't you go 1/4 inch fiberglass flagpole for the sight mount? That should be light enough that it won't be able to bend the steel mount I would assume. Just keep the flag small enough to not add too much drag
BroncoSarge
Jeffrey
TBH I have no idea. Prolly some of the smaller bolt on flag poles.
Advertisement
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
Not for the tailgate, but this may work for you if you have the modular bumper:
Ford Bronco Dune Flag Mount
I also wasn't wild about the trail sight mounted options, so I bought this and the handy Flag. Plan to install as my Bronco arrives. I like that this doesn't require other hardware and is fairly inexpensive.
evgenyvasenev
Evgeny
Gig Harbor, WA
vasenev.com
Jeep Renegate
I have the same flag and the same mount. I just increased the hole slightly. Haven't tried yet, but the new hole is just slightly bigger.
evgenyvasenev
Evgeny
Gig Harbor, WA
vasenev.com
Jeep Renegate
Speaking of rear VS front. I am not a big expert but I read to have a flag on the front is better as it's more visible on slopes from another side of a dune/hill.
BroncoSarge
Jeffrey
