@JimmyDean After your good break down of suspensions the other day I’m anxious to hear what you think.
I think Ford knocked it out of the park on everything except transmissions and subscriptions.@JimmyDean After your good break down of suspensions the other day I’m anxious to hear what you think.
Still can’t believe they went with “Wrangler” tires.
I would hold out a little longer until towing is confirmed. I know it says 3500lbs max towing but the towing specs still say TBD.You are correct. I have to tow and I bought a new Ranger to hold me over until the 2nd year Bronco's are out. I fully expected it to have at least 5000lb towing capacity, especially since the frame will be shared with the new Ranger. I really expected the 2dr would be minimum 5000 and the 4dr 6500(min).
Ford specs say 3500lb. I'm truely shocked Ford ignored the towing capacity. The new defender is 8000 and there's a slew of SUV's with well over 5000.
Now I have to rethink my plans and decide whether to go for the Defender or give into the wife and get a not so offroad worthy SUV.
Clearly Ford's focus was on off-road capability and handling, not towing. Also, short wheelbase vehicles generally suck for towing. If you want/need to tow heavier loads you're better off just buying a truck.You are correct. I have to tow and I bought a new Ranger to hold me over until the 2nd year Bronco's are out. I fully expected it to have at least 5000lb towing capacity, especially since the frame will be shared with the new Ranger. I really expected the 2dr would be minimum 5000 and the 4dr 6500(min).
I don’t like the rear brake line hugging the diff cover, that means it has to be bent out of the way every time the cover is removed.The bolts under the front A arms are what worry me the most. That is a really bad spot For bolts to hang down like that.
Your barking up the wrong tree if your comparing this to a defender. Have you looked at one? It’s unibody and has a floor low enough to mistake for a handicap accessible vehicle.You are correct. I have to tow and I bought a new Ranger to hold me over until the 2nd year Bronco's are out. I fully expected it to have at least 5000lb towing capacity, especially since the frame will be shared with the new Ranger. I really expected the 2dr would be minimum 5000 and the 4dr 6500(min).
no if you just slide it out downwards, like:I don’t like the rear brake line hugging the diff cover, that means it has to be bent out of the way every time the cover is removed.
I seeno if you just slide it out downwards, like:
That's not exactly how that works- you'll normally see something like a 3rd-party transmission rated at the max output of whatever engine they've sold it to a manufacturer for. If it's rated at 406, there's probably an engine it's used with that's factory rated at 406 and it's been tested to ensure it will survive normal use at 406. When you add power and crater a part, they point to that number and tell you to pound sand. The parts rarely get rated for more than they're being used for, except maybe in the case of general use parts.However, if you look at the max torque spec for the manual transmission it's only rated to 406ft-lbs. The 2.7L is purported to have 400ft-lbs. so it would be a weak point as far as durability and reliability go with the bigger engine. Better to have people bummed they can't get a feature at the start than totally pissed when their transmission grenades the first time they do some serious off-roading with it.
you need iron with all the stress a locker adds.Cast Iron front diff, aren't most IFS aluminum?
