- Caleb
- May 3, 2022
- 140
- 574
- 461
- St Louis MO
- 2021 Bronco
- Outer Banks
Just had a couple of these come in for stock! Only have a couple of them so act fast if you are interested!
Doing a pretty good deal on these while we have them, let me know!
These Ford Bronco NOVA-series full LED headlights will fit the following models:
21-23 Ford Bronco (Fits all models except Bronco Raptor, will verify fitment on Raptor after test fit)
* Does not fit Ford Bronco Sport
Design
We try to maintain the 6th Gen Bronco signature LED look and apply four of our patent 3D ice-cube projectors for these Ford Bronco NOVA-series headlights. Our LED work as DRL on the circle and straight tube, and also works as sequential turn signal light on the straight tube in amber color. The DRL comes with configurable white (default) or amber output, which gives you an option to upgrade to Raptor amber LED look. These Bronco headlights also come with activation light feature, which is a running light when you unlock your Bronco. All four projectors light up for low beam, while the bottom two projectors light up for high beam.
Projector Technology
We compose these Ford Bronco NOVA-series headlights with our patented Ice Cube 3D LED projector. We apply the Osram Oslon black flat LED chip for the low beam projectors and AlphaRex LUXX LED for the dual beam projectors. The projection cut-off line is perfect for American LHD regulation.
Feature
These Ford Bronco NOVA-series headlights come with switchback DRL, sequential turn signal light, and the signature activation light feature, which is a sequential light show when you unlock your Bronco.
Housing
Our Ford Bronco NOVA-series headlights come with black and alpha-black housing. The black housing is matte black finish with chrome accents to give your Bronco a sporty look and match with any chrome accessories on the body. Above all, the alpha-black housing is our special designed housing composed of glossy black finish with chrome delete interior. We also apply smoke tint on the DRL lens to give your Bronco an all-black look. Read this article to learn more detail about our headlights color housing.
Lens
Our Ford Bronco NOVA-series full LED headlights are made of polycarbonate plastic lens. We also apply a layer of anti-fog agent on the headlights lens; thus, it allows better light output in extreme weather. In addition, we also apply another coating to protect the lens against yellowing and oxidation.
SAE/DOT Compliance
Our Ford Bronco NOVA-series headlights are compliant with SAE and DOT FMVSS108 regulations. Moreover, all our products are certified to ISO-9000, ISO-9001 and ISO-9002. Most importantly, we inspect every detail of the lights to make sure we are satisfied and so are our customers.
Fitment
2022 Ford Bronco
2023 Ford Bronco
Design
Feature
Housing
Lens
SAE/DOT Compliance
Fitment
2022 Ford Bronco
2023 Ford Bronco
