EcoBco
Kevin
SE Michigan
I know it says preorder but any estimate on ship time for the bracket?
ChrisCozart
Hickory Creek, TX
2022 Bronco Black Diamond (non-Sas.)
Other than having airbags that may require a constant supply of air from a device like this, what is the benefit of having it hard mounted to the vehicle (exposed to elements and not portable) comparted to a portable unit that isn't exposed and is portable?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
4-6 weeks
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
1) It's not exposed to the elements, it's in your engine bay. So it can get some water/dirt on it but not like it's sitting outside.
2) It's designed to withstand abuse from the elements actually.
3) It's good if you go off-roading and like to air up/down (which you should) or want air with you at all times without worrying about carrying something extra.
4) It's a LOT faster then a portable.
I have a vair portable. It will go from 18-35 PSI in about 5-7 minutes per tire.
The ARB should do the same in about 60-90 seconds.
BroncoKong Jr.
Andrew
Do you also carry the ARB inflation kit? Or is a hose included with the compressor?
Golfmom
Carrie
Las Vegas NV
Carpooling Platinum Escalade ESV
Can I ask a dumb question? if I buy an adapter kit like this, can I use it with an ARB compressor to inflate my paddleboard?
Ford Bronco ARB Compressor Engine Bay Mount from KR Off-Road (NOW SHPIPING) 0B69535A-6B48-4D82-8D4A-F1D3876230DE
Packman
Honolulu
2011 Ford Mustang Pace Car
Great question. I’d like to use it to inflate my inflatable kayaks. Anybody know of an adaptor that works, let us know!
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Air is air. If you can use a normal compressor you can use the ARB, as it's a compressor...
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
We don't carry their air inflation kit (no margins on it). You can use any hose kit/air accessories with the ARB though.
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
Anyone plan on extending and mounting the air coupling? If so, where? Thanks.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Not sure where to put the coupler yet. That's more of a personal preference thing. I plan to just use the one on top of the air compressor myself.
EcoBco
Kevin
SE Michigan
I was honestly thinking of a spot to relocate the quick disconnect. Hard to pick when you live in a state that gets snow and salt lol I did read on ARB’s site that depending on the length of the relocation hose it has to be a certain diameter
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yeah there are a lot of options. An exterior rated spot with a capped outlet would be great. On my 2nd to last F150 I had, I had it in the bumper (the bumper itself had a little storage area with a door you could put stuff in).
For now i'll just pop my hood and plug the hose in there. Later on I may develop a mount somewhere ,but I'd want it hidden (easy enough to do)
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
The compressors are here. We wanted to ensure that when our brackets are back from production, we were not waiting on compressors. Sooooo we brought in a pallet worth of single/twin compressors today. This will ensure that the second our mounts are back from production all those pre-orders will ship out COMPLETELY.
So if you've been on the fence about getting a compressor, grab one. Remember, if you add-on a compressor with the purchase of our KR Off-Road ARB mount, you get 50% off the compressor mount
https://www.4x4truckleds.com/kr-off-road-arb-compressor-engine-bay-mount-for-2021-ford-bronco/
Ford Bronco ARB Compressor Engine Bay Mount from KR Off-Road (NOW SHPIPING) 1637632896574
