Doubleajaybrock
Aaron
2023 Bronco 2 Door 2.7L
Are they parallel with the existing holes or did the mounting height change with these new holes?
Thanks man
This is all I have. I did not take a photo before installation.
TireFlate
www.tireflate.com
Thanks man
The top hole is for the ground and oval shaped. I went straight over from that hole and measured for the bottom hole. I installed the ground wire in its original hole, not in the bracket.
Ford Bronco Injen Charge Pipes installed on 2.7 with Injen CAI IMG_1112
Doubleajaybrock
Aaron
Did relocating the holes effect the support beams bolting up?
TireFlate
www.tireflate.com
I did have to do some minor adjustments, but no other modifications. I did not use the base angle support bracket, but it is very solid even without it.
Tyistick
Tyi
Pasadena
2 Dr WildTrak
Word to the wise.
I have had my Injen charge pipes on now about 8 months and I recently added the CVfabrication Intercooler. I don't know how in the love of Sam I forgot to tighten down one of my couplers and I got on it this morning to pass a truck and as soon as it dropped down and spooled ... KABOOM!💥 The coupler that I didn't torque down gave lose. I think I may have brown stained my scrubs. It lost power and I thought for sure I shot a rod out the side of the motor. Pulled in a parking lot started looking under it...no visible damage..started looking for visible signs of turbo damage wiggling pipes... nothing. Hopped back in drove it and noticed right away only 2 psi max boost. But drove fine and no CEL's got to work popped the hood again and started wiggling and noticed the hot side going into the intercooler completely off...lol
Popped that som bitch completely off the pipe. So I went inside grabbed some 1000 grit sand rough the pipe up and hit it with 99% IPA and reattached and torqued it so hard my left nut twitched all day at work.
But just a reminder to retorq your charger pipes after they have been on a while.
Ninjak
Ninjak
Miami
2021 GT500 2021 Bronco Badlands 68 GTA
@Tyistick : I did this,(tighten my clamps) because I had spoke to a guy that is big into turbos and he told me due to the type of clamps I had, to go back and tighten them all down again.
I may get the other style clamps, but for now everything is holding up.
Tyistick
Tyi
Pasadena
2 Dr WildTrak
This scared the piss out of me...I thought for sure I jacked my motor up.
Don
Maine
2022 Bronco wildtrak
I just finished installing my pipes. I have the Whipple stage one kit which includes their intercooler. Everything seemed to fit fine. On my quick test drive turbo lag seems very minimal.
Ford Bronco Injen Charge Pipes installed on 2.7 with Injen CAI PXL_20240915_031032298
MWILD
Central North Carolina
2022/SAS/Mid/2.7L
Grab the Injen CAI - you’ll love it.
Ninjak
Ninjak
Miami
Russ.Cere
Lux Sponsor (Level 2)
Russ
modcrate.myshopify.com
Is that transfer case control module relocation bracket integrated into the compressor mount or is it separate? I am in the processing of making a relocation bracket for the TCCM so i can fab up a special intake.
B22-2023
Houston
This. They go hand in hand. Complete the system :)
I have everything installed and man, it was like cramming 57 midgets in a ‘57 Chevy. Very tight in there. But the pipes and CAI really woke up the 2.7L, even with the JB4 Burger tune off. 3 inch cat-back system helps too.
One practical dilemma is removing the air filter in the future to check and clean. Injen (gave such great support by the way) says remove the Y-pipe, but looks to me like removing the CAI box would be easier. What does anyone who’s done the install think?
