Injen X-Pedal Pro Throttle Controller For 2021-2022 Ford Bronco #PT0013B in stock at TMB!
ticklemybronco
Josh
Salem Ohio
2022 Bronco 4-door
Injen X-Pedal Pro Throttle Controller For 2021-2022 Ford Bronco PT0013B
X-Pedal Pro Throttle Controller by Injen®. What is X-Pedal Pro? In short, it is a simple plug-in module, which requires less than 5 minutes to install and delivers immediate, customized performance for your vehicle. Specifically, the X-Pedal Pro controls the throttle signals going into your stock ECU (Engine Control Unit), so that your vehicle instantly responds faster and accelerates swifter... or slower and more economically. The choice is yours.
Notes: This product is NOT legal for installation on vehicles required to meet CARB standards and/or registered in California and other states following CARB standards, including NY and ME
Features: Works With Performance Upgrades Mode Memory Easy Install Lock The Throttle The built-in high speed processor greatly improves throttle signal Sport Mode: 9 levels, suitable for mountain roads and racing
ECO Mode: 7 levels, suitable for driving in city areas which can improve fuel economy Anti-skid function allows your vehicle to launch on lower friction surfaces with ease Launch Control/Drag Race Mode: Gets you to reach max acceleration faster DAC (Digital to Analog Convert) - Digital signal output provides
How X-Pedal Pro Truly Works. Most vehicles today have replaced the older, traditional throttle cable with more modern ECU (engine Control Unit). What the aforementioned ECU does is, it translates the force of your foot on the accelerator pedal into electronic signals, which then tell the ETC ( Electronic Throttle Control) how much power to deliver to the wheels. This is also called a “Drive-By-Wire” system - which your vehicle manufacturer uses to deliver constant, generic performance to adjust the Drive-By-Wire into customized performance. Want some extra power to accelerate more quickly up a hill? simply press the “up” button on the X-Pedal Pro, and choose from several levels of performance enhancement. Need to save some gas as you idle through city traffic? Just click “down” button, and you’ll plenty of room to slow things down.
Simple Plugin Installation. The simplicity of the X-Pedal Pro allows for one of the easiest installations you’ve ever performed. Ever programmed a TV remote control? it takes about the same amount of the time and thought. There are no wires to cut or holes to drill. It’s literally, plug and play. Moreover, the X-Pedal Pro will notinterfere with your vehicle’s electronics, or any other performance modifications you may have made to your vehicle.
Injen Technology Company, Ltd., based in Pomona, California, was formed as a sister company to RD Metal Works in 1998, to utilize the experience and design capabilities that RD Metal Works had gained designing and manufacturing air intake kits for leading air filter and intake manufacturers. Since that time, the company has made it a point to stay at the forefront of performance technology, continually setting new standards for quality and improving their engineering and manufacturing capabilities. This enables Injen to regularly introduce new, cutting edge products to market and has required the company to continually expand to meet the demand for those products. Today, Injen continues to set the industry benchmark for innovation, styling and technology.
Injen Technology offers a Limited One-Year Warranty to the original purchaser against defects in material and workmanship on all Injen electronics under the PowerTech line. Injen Technology will replace, at no charge, any Powertech electronic component considered by Injen Technology to be defective. Any and all warranty coverage is limited to the repair or replacement of the defective part only, at Injen Technology’s discretion. Proof of purchase is required. The warranty does not cover incidental or consequential damages, damages caused from improper installation, nor does it cover the cost of installation or removal of the defective part or its replacement.
Fitment: 2021-2022 Ford Bronco
Advertisement
