VinceMBadlands
Vince
2022 Bronco Badlands, SAS, Mic, 2.7, Lux, MR701
Has anyone gotten an awning on the factory rails?
Apparently yes, but probably just the straight pull one. I've got a 180 awning and it requires 3 brackets. The one that will be tricky is the rear cross aero bar as the roof clamp on the OEM roof rails are higher and larger than the middle aero bars. Ford should of had a T-slot track running across their aero bars to avoid this issue.
I'll update you when the after market clamps arrive.
VinceMBadlands
Vince
Yes!! Just finished my build with an OVS 180 on OEM rails. It took some trial and error, I'm super happy with how it's turned out. It's not too high off the rails and feels solid.
I got aero bar clamps from eTrailer, mounting plates from Amazon. Then used some 3/8 -16 zinc bolts.
Well see how it holds up on the freeway, may add another mounting plat underneath for extra strength. Hopefully a more solid clamp or some produces a TSlot bar that fits the OEM roof rails.
Ford Bronco Inspired Overland RTT and Hooke Roof Rack installed 20230614_192420~2
Ford Bronco Inspired Overland RTT and Hooke Roof Rack installed 20230614_192457~3
Ford Bronco Inspired Overland RTT and Hooke Roof Rack installed 20230614_190741~2
Ford Bronco Inspired Overland RTT and Hooke Roof Rack installed 20230614_190753~2
Ford Bronco Inspired Overland RTT and Hooke Roof Rack installed 20230614_190650~2
Ford Bronco Inspired Overland RTT and Hooke Roof Rack installed 20230614_190731~2
Ford Bronco Inspired Overland RTT and Hooke Roof Rack installed 20230614_190708
Ford Bronco Inspired Overland RTT and Hooke Roof Rack installed 20230614_190701
Ford Bronco Inspired Overland RTT and Hooke Roof Rack installed 20230614_202228
Ford Bronco Inspired Overland RTT and Hooke Roof Rack installed 20230614_202217~2
Stinger06
Madison, WI
Does anyone know what eye bolts fit in the t slots? I just installed mine yesterday. I’m getting prepped for some trips in the near future.
TheLast10mm
Everglades
Nj
2024 Bronco Everglades, 2022 Explorer St
Everglades
Any chance you have the links to the Aero bar clamps and adapters you used ?
