Installed amber Rigid rock lights from Ford accessories
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
Nicely done. Thanks for the share.
TennesseeBronco
TennesseeBronco
Josh
Tennessee
Sedan
Thought you all might like to see how I connected to auxiliary switch wiring under the hood. Black wires are grounds. Red wires are live. Each light has a ground and live wire. I installed the red post seen here and ran 4 light wires to it. Then one wire from it to the yellow wire that is wired to auxiliary switch #1. The other wires next to the yellow wire are other auxiliary switches.
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
Is there any guidance on proper placement in the instructions?
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
I’m curious if there’s a way to mount them to the flares themselves. I guess it would need to be removable as well, so maybe not just with epoxy.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Please don't take this the wrong way. But DO NOT do that with the positive (red post) at all. That's VERY VERY VERY dangerous.
First, your positive feed from your terminal is using too small of a gauge wire for all the accessories you are running. 2nd, I can't see it in the photo but i'm HOPING you put a fuse in line, near the battery terminal?
Notice how your positive terminal on the battery has a big red plastic cover on it. That's to shield the positive terminal from the rest of the vehicle. That's VERY dangerous, look how close your ring terminals are to that bolt holding the plastic piece down. It's VERY CLOSE. You're going to end up setting something on fire.
Also, i don't see any fuses on your accessories off your positive feed. EVERY accessory MUST HAVE a fuse located as close to the positive power source as possible.
Just trying to help. I realize you do not do this for a living, so I want to make sure you do it safely. Positive distribution systems ALWAYS need to be protected/shielded so that ground wires can't accidentally touch them.
Your positive wires off your accessories are already nicked and are resting against the chasis. That things gonna go up in flames.
swooshdave
Portland, Oregon
Mustang
Notice how your positive terminal has a big red plastic cover on it. That's to shield the positive terminal from the rest of the vehicle. That's VERY dangerous, look how close your ring terminals are to that bolt holding the plastic piece down. It's VERY CLOSE. You're going to end up setting something on fire.
Isn't the auxiliary wiring already fused?
What size wires would you run? There's very little amperage with the LEDs, right?
That power stud scares be too. And the nicked wires. Laying on metal.
Ford Bronco Installed amber Rigid rock lights from Ford accessories 20210921_135234
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I see the upfitter now. I'm guessing that upfitter wire is feeding that terminal mess (sorry it is a mess). The upfitter IS fused, which is good. But that's still not a good place for a terminal block. It's also completely unnecessary to have junction point for those wires (rock lights I assume correct?). Just twist the 4 rock light wires together and crimp them onto the aux wire. They don't pull a lot of amps but still, that terminal block is dangerous.
NatureMan
United States
Do you have, or plan on providing color picture installation procedures for products that you sell? I can see it being very beneficial.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yes. I actually posted a thread about the Baja Designs reverse kit over over the weekend as well as a post about an aftermarket switch panel I installed yesterday as well. They are in this lighting section.
We'll probably be doing an installation video showing how to install the various kits as well.
NatureMan
United States
Thank you.
swooshdave
Portland, Oregon
Mustang
I agree with the block. I can see why @TennesseeBronco wanted to have a clean place to join the wires together. The intent was good.
The picture cuts it off but I believe the yellow wire is from the switch which is joined to a red wire that goes to the block.
I'm still looking for better solutions for wiring terminals for joining 2, 3 or even 4 wires into 1.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Use these. I've made relay panels in the past out of them and on my daughters powerwheels I've used them (yes, I put lots of Baja Designs lights on my daughters power wheels)
Terminal Blocks: https://www.amazon.com/s?k=terminal+block&ref=nb_sb_noss_2
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
I got the white ones and am going to have the dealership install them. I’m a master of disaster when it comes to wiring anything on a vehicle. They’ll probably have a better idea of where to place the lights in the wheel well also.
