Installed amber Rigid rock lights from Ford accessories
FourHorses
Currently own 6 Fords
By the shadows, we are looking at a real Sasquatch!
Ford Bronco Installed amber Rigid rock lights from Ford accessories ?u=https%3A%2F%2Ftse1.mm.bing.net%2Fth%3Fid%3DOIP
Bronc-O
Phoenix
2021 Lincoln Aviator
Isn't the auxiliary wiring already fused?
What size wires would you run? There's very little amperage with the LEDs, right?
That power stud scares be too. And the nicked wires. Laying on metal.
That wire where the arrow is pointing is really concerning. When that rubs through, you'll be having a meltdown. There should be heat shrink covering those.
swooshdave
Portland, Oregon
Mustang
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
That one has a cover. Just not shown in that photo.
There ya go. Mount them to a piece of metal and bolt the metal in the engine bay somewhere.
Daktari
Oliver
interesting, but those giant shadows kind of defeat the purpose IMO. Maybe something mounted directly to the flares, could even be an LED strip of some sort, don't need stadium lighting to see rocks in the dark.
Thanks for sharing, but I also have to agree with 4x4truck here, you need to make the wiring much safer, and why are is the insulation on several of the wires broken? Did you accidentally cut through or is the wire of such bad quality that the insulation just cracks?
swooshdave
Portland, Oregon
Mustang
They look like cuts from trimming the wire cover back.
BroncoBill6G
Circleville, Ohio
2008 F350, 2017 Lincoln MKZ, 2018 Escape, 2016 Fus
What size or type screws/bolts did you use on the rear and type on front? Did you go threw metal?
WhiteMamba
Derek
Boring, Oregon
2021 Bronco FE, 2015 F350 2010 Focus 1995 F250
I just did white rigid rock lights, used self tappers first and then came back with some black metal screws for a cleaner look.
rcloke0124
Robert
2022 Ford Bronco 4-Door, Sasquatch
Ford Bronco Installed amber Rigid rock lights from Ford accessories 4FE93ABF-7470-41E1-9FBA-F8F1A886883A
I like the idea of these lights. Especially if doing on trail repairs or uses the front wheel cameras at night to aid in navigation.
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
They look nice, but for half the price, minus install, could have gotten 8 rgbw rock lights or as with my old truck, 12
Ford Bronco Installed amber Rigid rock lights from Ford accessories 43FCA56D-2985-4C61-959F-AD92CEC7CDE2
p3pete
Pete
Newport, RI
03 Cobra, 23 Bronco Raptor
My dealership installed the rigids before I picked her up. Seems like they're mounted in different places then yours?
Ford Bronco Installed amber Rigid rock lights from Ford accessories Rock Lights
Deleted member 32220
Guest
Typically they are put in the wheel wells, but like anything else in life you can put them anywhere you see fit, or prefer the look of.
