- Banned
I installed the JL Audio C2 650 x kick panel speakers yesterday.
A few notes:
A few notes:
- As previously mentioned, the dead pedal (drivers side) has a false front that can be pried up to reveal 2 10mm nuts.
- I used a 9/32 nut driver to remove the topmost screw.
- Scuff plate pops up easily.
- The metra 72-5602 harness fits perfectly.
- The factory harness is outside the factory speaker hole which means the metra harness would be pinched under the speaker when installed.
- I had the bright idea to drill a 3/8hole in the side of the jl speaker adapter. Worked well on 1 speaker but I got carried away on the 2nd one and drilled through the speaker cone (%!?%$@&!!!).
- Passenger side was a breeze.
- The speaker has a tweeter cone which was a bit higher than flush which prevents the POS speaker grill from staying closed…
- The JL speakers came with some trim tools so that was a plus
Anyway, hope this helps anyone looking to replace the kick panel speakers…
