Installed Rough Country 3.5 Ditch Lights with Amber Daytime Running Lamps.
subg
Illinois
2023 Base Bronco 2 Door
Hi,
Installed the Rough Country 3.5" round ditch lights this weekend. Figured I would try these before spending 2-4x more on other options.
First, they have 2 versions. A universal kit for 89.95:
https://www.roughcountry.com/3-5-inch-black-series-led-lights-70900.html
And a Bronco specific kit for 109.95:
https://www.roughcountry.com/bronco...ml?find=2023-ford-bronco--2-door--4wd-1003420
I made the mistake of buying the bronco specific kit. The only difference is the plastic spacer they provide with the Bronco kit. So, you're paying $20 for 2 plastic bushings. I didn't even use the bushings because they sat too high and that in turn caused the factory screw to not engage enough threads when installing the mounting bracket. I just used several small plastic washers from Ace, and a larger one on top of that to keep the bracket from touching the factory trim panel.
The lights come with a nice harness that does not require upfitter switches. I have the switches, so cut the harness and wired the two white wires for the ditch lights to switch 3 and the two blue wires to switch 4 for the DRL's. I pigtailed the 2 black wires and grounded them on the firewall:
Ford Bronco Installed Rough Country 3.5 Ditch Lights with Amber Daytime Running Lamps. 1682902082959
Ford Bronco Installed Rough Country 3.5 Ditch Lights with Amber Daytime Running Lamps. 1682902158016
Here's the Ditch lights at dusk:
The DRL's:
And the Ditch lights at night:
Ford Bronco Installed Rough Country 3.5 Ditch Lights with Amber Daytime Running Lamps. 1682902861721
Overall, very happy with them. The quality is great, and the price seems fair.
D.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
I have these as well and really like them and the dual function. Have had them for a few months now with no issues.
Jeffola
Southeast Florida
2023 Bronco, 2023 Hyundai Santa-Fe, 2019 GT350
Just did mine yesterday along with a set of grill marker lights. I did get the set with the spacers. My bolts were long enough for them. Also pretty impressed.
subg
Illinois
I purchased the Rigid lights @ 3600 lumens, and these were 3200. I've seen some as high as 7000, so wasn't sure if they would be bright enough. Just returned the Rigids.
They're plenty bright. For me, just a security feature in case I get held up once it starts getting dark. Headed to the Shawnee National Forest next month, and Moab later this summer.
Only thing left is a compact cooler, my big one takes up too much space in the 2 door, and a portable recovery device that's not my ratcheting comealong!
Geronimo
Wisconsin
Tacoma, Bronco Badlands Sad on order!
I have them also and like a lot. I think very good for the price. I think the white is plenty bright also.
Ford Bronco Installed Rough Country 3.5 Ditch Lights with Amber Daytime Running Lamps. 20230320_223929
Mlarv
TN
2023 Bronco/ 2022 F150/ 1968 Mustang
I am glad I found this post. I ordered these same lights yesterday. I wasn't sure how good they were going to be. I figured if I didn't like them I could send them back. By the looks of yours I think I will be happy with them.
Geronimo
Wisconsin
👍I think you will not be disappointed. 😎
DOUBLED16
Daniel
Canada
2020 Ford Escape Hybrid
Where did you get your grille marker lights? The only thing I can't stand with my OBX is the grille.
Jeffola
Southeast Florida
I ordered these from Amazon
Used spare plastic from mudflaps, heated and bent them. mounted the light to plastic, plastic to the grill and wire away.
cbol
Candler
Georgia
2023 Ford Bronco
Hi,
The DRL's:
D.
Has anyone wired these lights to be used with highbeam and normal DRL? Basically eliminating the purpose of the switch.
