Installing overhead aux switches after sales?
NewBroncoOwner
Well why in the heck is it over there? lol. The box i bought was $125, better than the $400+ for same capabilities. Also, I have come too far now lol
Advertisement
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Got that 6 Gang switch kit from amazon. Real easy to mount in the cab, I utilized the Ford Bronco plate screws to mount the supplied mounting bracket under the plate. Seems like much of this truck is accessory ready! Lights will go on soon, they are on back order.
I plan to use the 8 switch version of this. We stock the AuxBeam panels here at 4x4TruckLEDs.com
NewBroncoOwner
I think the connector going up is on the passenger side. C206
Connector Viewer - 150
C100AC100BC101C105C106C107C108C109C110C111C112C113C114C119C121C122C123C124C127C134C135C136C137C138C140C149C150C152C155C160C162C163C167C168AC168BC168CC171C175BC175EC177C181C182C183C184C192C197AC197BC200C201C203C205C206C207C209C210C212C216AC216BC217C218AC218BC218DC218EC218GC220AC220BC221C222C226AC226BC228AC228BC229C229AC229BC229CC233C236C240AC240BC240CC240DC248C256C258AC258BC259AC259BC266C278C285C286C289C296C297C300C301C302C305C310AC310BC318AC318CC319C322C322AC322BC322CC326C328BC328CC331C332C334C335C337C339C350C356C360C362C363C364C365C367C381C383C390C391C392C393C394C402AC402BC404C405C406C410C411C413C414C415C416C420C421C424C425C426C429C431C432C435C436C440C445C446C447C450C475C476C505C525C540C567C573C605C606C608C634C644C726C750C828C850C906C907C908C911C930AC930BC930CC930DC963C1016C1019C1021C1026C1033C1035AC1035BC1035CC1041C1047C1052C1062C1068C1073C1074C1077C1087C1100AC1100BC1100CC1100GC1100JC1101C1102C1104AC1104BC1104CC1107C1111C1112C1120C1137C1139C1140C1147C1148C1149C1151C1153C1160C1222C1271C1292C1293C1294AC1294BC1295AC1295BC1322C1323C1331C1365C1366C1367C1369C1370C1400C1401C1415C1416C1427C1428C1429C1430C1431C1445C1446C1450C1463AC1463BC1465C1466C1469C1513C1551BC1551EC1551TC1561C1562C1563C1564C1565C1566C1570C1582C1584C1615C1616C1617AC1617BC1617CC1617DC1617EC1617FC1617GC1621C1625C1627C1631C1632C1642C1643C1647C1648C1649C1655C1663C1674C1682C1689C1690C1702C1741C1748C1751C1766C1767C1792C1795C1836C1837C1840C1841C1842C1843C1844C1845C1846C1847C1848C1854C1895C1896C1901C1902C1903C1904C1905C1906C1915C1991C1992C1993C1994C1995C1996C2010C2010AC2010BC2010CC2039C2040C2091C2092C2122C2195C2235C2253C2254AC2254BC2280AC2280BC2280CC2280DC2280EC2280FC2280GC2280HC2354C2355C2356C2357C2363C2364C2370C2371C2383AC2383BC2383CC2383DC2383EC2383FC2383GC2385AC2385BC2385CC2405C2406AC2406BC2407AC2407BC2420C2421C2431AC2431CCC2431CDC2431CEC2436C2437C2438C2439C2490C2491C2494AC2494BC2494CC2515AC2515BC2515CC2515DC2564C2565C2608C2809C3006C3007C3051C3059C3075C3106C3159C3187C3189C3200C3201C3209C3210C3211C3212C3215C3216C3220C3240C3243C3245C3247C3318C3319C3323C3336C3336AC3336BC3336CC3338AC3338BC3388C3501C3502AC3502BC3522C3558C3559C3697C3698C3734C3825C4029C4046C4049C4099C4213C4223C4226AC4226BC4287C4320C4321C4330C4331C4336C4357C4359C4360C4369C4370C4397AC4397BC4397CC4452AC4452BC4452CC4478C4479C4544C4545C4546C4547C9018C9019C9026C9035C9064C9066C9224C9440AC9440BC9531​
Inline:DescriptionColorHarnessBase Part #Service Pigtail
C206INLINE14401 14335See Below
MALE
Harness
14401
FEMALE
Harness
14335
Check for Terminal Part Numbers
PinCircuitGaugeQualifier
1**
2CBP02 (GN)20
3CAC12 (GY-OG)14
4CMT18 (VT-OG)22
5RMT10 (VT-GN)22
6VMF05 (GY-BU)22
7VMF04 (BN-BU)22
8**
9CLN09 (YE-GN)22
10**
11**
12CMT10 (BU-BN)22
13VLN04 (VT-GY)22
14GD216 (BK-VT)20
15VDB25 (GN-OG)22
16VDB26 (GY-BU)22
17**
18**
19**
20**
1**
2CBP02 (GN)20
3CAC12 (GY-OG)14
4CMT18 (VT-OG)22
5RMT10 (VT-GN)22
6VMF05 (GY-BU)22
7VMF04 (BN-BU)22
8CBBD9 (BN-WH)22
9CLN09 (YE-GN)22
10DMM13 (BK)22
11**
12CMT10 (BU-BN)22
13VLN04 (VT-GY)22
14GD216 (BK-VT)20
14GD216 (BK-VT)22
15VDB25 (GN-OG)22
16VDB26 (GY-BU)22
17**
18**
19RMM13 (BU)22
20VMM13 (YE-GN)22
You can buy the upper harness for one with aux.
For S&Gs I checked the passenger side A pillar for that harness connection, with no luck on the base trim. Thanks for the schematics @flip they are helpful for understanding where harness connections are to be found in the future.
Southern Girl
1974 Bronco/2013 F-150 4x4/2021 Outer Banks Bronco
Vehicle Showcase
When you install, can you do a video? I don't need them now per se, but I ordered and the Bronco I have now isn't my order. I have a few things I would like to add, but no aux switches.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Sure. I may do it today
4x4TruckLEDs.com
Adam
Lindenhurst, NY
NewBroncoOwner
***Update to finding out if you have the up fitter harness from the factory;
This is the Fuse box under the hood, left is the front of the truck. These 3 fuses circled in red are your AUX switches fuse location. In the manual these are marked as 20s (if equipped) but if you have 5s, there are no harness' to install the OEM switches within the cab.
Canonman11
Tim
Tampa, FL
I would hope there might be some way to get them installed down the road? Not the news everyone was looking for but thanks for the effort. Was this confirmed by Ford?
Lagrange 6g
Tony
Austin , tx
2018 f250 2014 landcruiser 1978 cj5
Did your Super Duty switch assembly looked like this?
I tried to do an image search for the part number that @flip posted, but it’s so new, there were no images available. The Super Duty switch assembly showed up during the same search, though, so I’m assuming the two switch assemblies might be similar even though the part numbers and actual dimensions and features are probably different.
First pic is bronco second is 2018 f250
NewBroncoOwner
Maybe possible, But I am pretty confident with the previous looking I performed on both of the A pillars and my electrical engineering background, There is no way a 5 amp fuse is capable to handle any aftermarket powered accessories, or a wiring harness. This is why Page 310+ in the owners manual shows a 20 amp if equipped. Having 5 amps on the fuse block seems it is necessary to pass power to other parts of the block, being wired in series.
Advertisement
Apollo Optics
Advertisement
