Installing overhead aux switches after sales?
Status
Not open for further replies.
Jen
Northern VA
21 Bronco BB 4D, '97 BMW 323ti, '90 Miata, '02 NSX
Yup. Had better luck at the parts counter of a different dealer. That part is +$450 (!!!) so we’re going to get into it and see if there isn’t a nice DIY alternative, likely using the existing sunglass pocket piece. Sorry, it’s not high on the To Do list, but it is on there…promise!
The accompanying part needed is the Overhead console panel in addition to the switches (https://www.oemfordpartsdirect.com/oem-parts/ford-console-assembly-overhead-m2dz78519a70jc)
Canonman11
Tim
Tampa, FL
Pretty expensive to build after taking delivery. But I was lucky to get a hold of one as an abandoned order. I think i will be ordering and doing an install video for others.
Can’t wait I am going to order myself as well. Worth the money to get them installed. Should be standard on all Broncos. Will be looking for the install.
Justin
Deep Creek Lake, MD
2021 Bronco OBX 2.3 4 Door, 2021 Yukon Denali Dmax
Can’t wait to see this
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I'm going to be doing this to my Bronco (if/when I get it) as it doesn't have the upfitters.
So $370.01 for the switch panel/console isn't bad. I had a 2015 F150 XLT and I paid about $400-$500 for the upfitter panel. It was an entire assembly. I also had to buy the wire harness (which I cut as I just needed the connector and ran my own wires to the leads I needed). It was from a Super Duty/Raptor but fit the 2015 F150s. It was worth it in the end. I had to make a relay panel though, so for $370 or so on a Bronco, not bad. Relays/harness should already be in place for an easy plug and play solution.
Southern Girl
1974 Bronco/2023 Bronco
Me too. Please tag me if you post anything you learn about this!
Exomodo
Ryan
Marquette, MI
Ranger
Or scroll to the top of this thread and click "watch" and select e-mails to keep an eye on this and other threads of interest.
Southern Girl
Thanks, but I don't really need that type of assistance.
Firefight911
Phil
Simpsonville, South Carolina
2022 Ford Bronco 4-door Wildtrak, Eruption Green
Southern Girl
Thank you for this information! I didn't expect to find a Bronco available and it did not have everything I ordered, including aux switches. This is encouraging.
NewBroncoOwner
Good Ol USA!!!
2021 Ford Bronco Base
After pulling the overhead trim In my base bronco, there are no wires or connectors ready for aux switches for direct plug and play. Save yourself $400+ to install after the fact.
Ford Bronco Installing overhead aux switches after sales? D406E7EA-5BA1-4142-8C07-378821934DDA
Ford Bronco Installing overhead aux switches after sales? 252035C2-4E8B-4C6C-9984-A517E671637F
Ford Bronco Installing overhead aux switches after sales? DE8552B0-C866-46EB-BD67-21962F59D73F
Ford Bronco Installing overhead aux switches after sales? F0F27287-EE33-47EA-A9F6-464C5F400DCC
Canonman11
Tim
Tampa, FL
On your base Bronco did you see the wires in the engine area. On my outer banks I am seeing all the wiring through the truck I just need to verify where you did? Was the top piece easy to pop down I need to verify mine since I see wiring.
Southern Girl
After pulling the overhead trim I’m my base bronco, there are no wires or connectors ready for aux switches for direct plug and play. Save yourself $400+ to install after the fact.
Being dumb about this, what would be needed to add a wiring harness there? I am assuming it's tons of work.
Status
