I’m optimistic Ford will fix the known issues by 2021 release.
I have a '18 F150 lemon. At one point they replaced a pump on the trans that was causing excess pressure. That fixed the clunk for a while but now it's back. Lots of reprograms. My clunk is so bad I always have to look to see if I got rear ended. Another thing mine does (or doesn't do) is hesitate to shift when it's cold, then slams into 2nd gear almost causing whiplash.I had a 17 Camaro ZL1 with the 10-speed automatic and it was flawless. I mean seriously, it was amazing across the board and don't use the word amazing often. I bought my current 2018 F150 3.5L FX4 with the 10R80 and honestly, the transmission is the worst part of the truck. I tried to get them to flash mine but it came after the TSB date. Some issues I have:
In general, I've found the transmission is fine in any gear above 5th. It's clunky and especially so when cold in gears 1-4. Resetting the adaptive learning does little to help. Compared to the ZF 8-speed into various FCA products, the 10-speed shifts like crap. Compared to the 10-speed in the ZL1, it shifts like complete hot garbage. I'm going to take it in within the next few weeks to see if they'll flash it and look into the vibration. I honestly feel like there might be something more than a flash issue wrong with my transmission, like fluid level or something in the valve body.
- Shift flare when cold.
- Harsh or clunky shifts when cold.
- Hard engagement into D when hot. This happens randomly but it will slam into gear. For example, sitting in a drive-thru waiting. I'll shift the truck into N and when I shift into D, BOOM. I guess it's the hidden neutral drop drive mode.
- Rumble strip vibration when decelerating to a stop which occurs around 21->13 MPH. Shifting into neutral eliminates the vibration completely. Could be driveline related.
Hoping the Bronco will be better. I'm trading the F150 for the Bronco 4-Door FE, so my fingers are going to be crossed. How GM got it so right and Ford got it so wrong just blows my mind.
I'm not.I’m optimistic Ford will fix the known issues by 2021 release.
5k on my personal 40k on my work truck. My Bronco will be very low mileage as well. Highest mileage personal vehicle I’ve had Since 2012 was 12k miles.Could you provide us with an estimated mileage you have on those two vehicles?
Haven’t heard one way or other if there is a trans cooler. Most fords have transmission temp in the center display however the bronco is all new. New gauges. We shall see. But I imagine it will be included.My concern is this being my first slush box in a trail truck, what kind of cooling they have for the juice. Heat is the #1 killer for an auto trans. I hope they offer a AT temp gauge.
What is the 1st gear ratio of the 10 speed?
I agree most people are very happy with the 10 spd; it is a very small percentage that have problems. I am confident and will be getting the 10 spd. The little twin turbo is a great motor![/QUOTE]I have the 10spd in my 2019 Ranger and it has been flawless
