Okay, I just took some measurements using my laser measure and a 6’ level across the base of the seat where the base and the back meet. In my stock Black Diamond non-Sas, with its adjustable seat height, the range is from 30.5” to 33.3” from the ground.Is BD ride height similar to ‘22 ford ranger ?
Yep, stock Grabbers (optional wheels, but same size as the steelies), no lift. I assume the Ranger owner was talking stock or he would have specified. You can do more searching on the Ranger. This was just the first one I found…Tire size would impact this as well. Your BD stock 32’s vs whatever stock on ranger ?
How do you like the ride height and ride feel ?Yep, stock Grabbers (optional wheels, but same size as the steelies), no lift. I assume the Ranger owner was talking stock or he would have specified. You can do more searching on the Ranger. This was just the first one I found…
Can’t wait. It’s a little bigger - wider and taller- but not much, maybe more ride height, rougher ride, and tires are bigger,Yeah, it’s going to feel big and tall for a little while, but it’s super easy to drive and you should get used to it in no time…
