- Jim
- May 25, 2017
- 45
- 1,311
- 1,299
- jackson nj
- 59 Bird, 70, 74, 78, 79 Broncos, 84 LTD 331 w/Vortech, 86 Capri 5.0 turbo, 14 Stang GT, 17 Fusion Sport
- Undecided
10 speeds between F150 and Bronco seem about the same ratios (with the very slight edge going to bronc in 1rst/2nd).
https://www.ford.com/cmslibs/conten...21/mediakit/21_Bronco_Prelim_Tech_Specs_1.pdf
http://www.f150hub.com/trans/10r80.html
The big difference is after that. 3:1 case, 4.7 diff, and a rear D44 for the Bronco. (see above)
Yet the F150 gets at least an 8.8 and many come with a 9.75.
https://www.f150forum.com/f118/what-size-rear-axle-housing-do-2-7l-eco-boost-trucks-use-311245/
So even if they are the same weight vehicle, it could be the rear diff that Ford
is trying to protect.
The ECO's, after the turbo lag, ramp up the torque very quickly. Possibly too quick, especially
in first gear when you are talking almost 70:1, overall ratio, and heavy 35's (which yes does knock down
the effective ratio some compared to F150).
Heck the D44 was the FRONT diff in every FSB ever made (about the same weight as a loaded 4 door bronco),
and those supposedly have total POS engines compared to the Broncos offering (according to at least 30 % of
he people on here).
Anyway, just another thought on a possible reason for the nannies.
he people on here).
