Is the 2.7L V6 a new engine or established?
GYMEBronco22
Maine
F150, Focus RS
I have a 19 F150 3.5 A10, its flawless, the 2.7 from the 2018+ camp seem to be indestructible hence why I am getting a 2.7. usually takes 2 year cycle to get the kinks out of a newer gen engine. i dont think you can go wrong with either Bronco engine, they are both proven.
I was very concerned about Ford using the F150 2.7 in the new Bronco, but you say the 2018+ engine is a good one, which leads me to believe Ford have addressed the well known cold start smoking problems they had.
I have a 2.7 2017 F150 (Nov 2016 build) with less then 50k and its been smoking on cold start for the last few months. After new turbo/seals and heads, it's now doing an oil consumption test, after which the dealer told me to expect a new engine!
Hopefully these problems have been rectified for the Bronco. Does anyone know for sure what engine upgrades have been made or is Ford using the same F150 engine?
Bauer
IL
Chevy
Well.. you can buy the engine block heater option for $100.
Gquag
Geoff
1936 Ford Pickup
I did poke around the forums a bit for an answer on this but did not come across it. I apologize if this information is out there and I did not find it. There is a lot more information, oddly, on the 2.3L 4 cyl.
Is this an established motor that has been running on other ford vehicles for some time, or is this a new eng they are making for the Bronco? I am always hesitant on new technologies in vehicles not being reliable. Sometimes it takes auto makers a few generations to really nail the tech - at least in my experience.
Thanks in advance.
There are a few bolt on Mods which can increase your HP around 40 to 60hp and improve your air flow and exhaust flow which in turn can improve your MPG.. And then tuning its a bit $$ depending.
I watched a few youtube videos
GYMEBronco22
Maine
F150, Focus RS
Just to clarify - when I say cold start I mean the engine is cold - not the air temperature is cold. An engine heater wouldn't do anything to address the smoking issue.
AzScorpion
2019 Ford Ranger SuperCrew Lariat 4x4
I have the 2.3 in my Ranger and I have a Livernois tune. It was $500 and you receive every tune they have, currently 5. The 91-93 performance tune adds 80 hp and 100 lbs torque. You can flash back to stock in 2-3 minutes for when you're off roading. There is no better bang for your buck than this as you won't get this add hp by adding an exhaust.
I'll be adding this to my 2.7 Bronco as soon as they come out with one. Also they give you free tunes for life so if you sell your vehicle you just send them your MyCal tuner and they reprogram it to your new vehicle.
Toaster
Mars
ā€˜18 JLUR, ā€˜19 Raptor
I drove an Edge ST (has the 2.7L) for a bit and it really is an awesome little engine. I highly doubt youā€™ll run into any issues with it, Ford has got the EcoBoost figured out now. Iā€™m quite excited to see how the power translates from the ST to the Bronco in regards to the 35ā€™s mine will be rolling. Either way Iā€™m fully confident that I wonā€™t have to worry about any engine issues and you shouldnā€™t worry either :)
jdub.csu
Jon
2019 Subaru Forester, 2020 Honda, 2015 Mustang GT
The 2018+ 2.7 engine is fantastic. The pre 18s had some issues that was fixed with the direct port injection and some other minor changes.
The 2.3 is also proven... but I wouldnā€™t buy it because it is currently direct injection only and carbon deposits become a problem. That is one of the ecoboost engines that still needs that update.
lrtexasman
Larry
Dallas, Tx
2022 BL traded for 23 Tundra waiting on BD Order
2.7 was updated in 2018
Gloff
Sean
San Francisco
www.serramonteford.com
'21 Ford Bronco Big Bend, '03 BMW Z4
The 2.7L was designed from the ground up as a boosted engine. This is unique to that engine, as all the other EcoBoosts are derivatives of engines Ford developed or co-developed as NA engines.
Ford spent a lot of energy on the details, and I think it is a great engine. CGI Block, offset piston rods, fracture cracked mains cast with the engine. Lots of high tech, high strength features. In my mind, they effectively built a diesel that runs on gasoline. I think the thought was that if they were going to put a small displacement turbo in the F-150, it better be overbuilt, as it will likely get overworked.
"The bearing caps, also in CGI, are laser-etched at an angle, Waszczenko explained. The specific angle creates a wedge effect that when the sections are merely set together, the engine actually would be able to run without the cap bolts."
Razorback
Bill
Dallas
Lincoln MKX
It was in my MKX that the lease just ended. I had the AWD with the 2.7L and when in sport mode, it was a bullet. It would keep pulling through 70mph. No question I'm getting the 2.7L in the Bronco.
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2023 GMC AT4 HDD
You donā€™t want a GDI engine. Get the 2.7L.
XCR440
Nathan
Union, Iowa
Mustang GT, 22 Badlands 2 door
Did they do the oil line TSB, we've had a couple with that issue (LOTS of smoke after starting when its been sitting 48 hours or more), was an oil line to the turbo that fixed them.
