Is the 4 Door Cargo Area Enclosure Deluxe Raised compatible with the 4 Door Cargo Liner?
BroncoBuck
Ohio
Toyota
Curious if anyone knows if the 4 Door Cargo Area Liner (i.e., the rubber cargo area mat/protector) will fit if a 4 door Bronco also has the 4 Door Cargo Area Enclosure Deluxe Raised Lid? The Cargo Area Enclosure's side walls seems to take up a small bit of space on each side of the Bronco's cargo area when installed. That being the case, will the 4 Door Cargo Liner (the rubber mat with the white Bronco logo) still fit in the cargo area?
Any insight/help is greatly appreciated!
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
It will likely require a trim as the enclosure stands off the sides and back by an inch or so.
