Is the Wildtrak on lift kit or just bigger tires ? ? ? ?
2fast4u
Rancho Cucamonga CA.
Shelby GT500 and Bronco Wildtrak
Is it Raised stock? or just taller due to tires?
BroncoFanBoy
Brandon
Az
Nissan
WT includes Sasquatch as standard equipment. Sasquatch includes “high-clearance” suspension. I think it sits almost 2 inches higher than a model with 32s, someone posted some specs a while back.
FirstOnRaceDay
Devin
Toledo Ohio
17 Civic, 19.5 Silverado
wild track is the Sasquatch package which is about 1” lift over the badlands. Also the tires are 2” taller resulting in a 2” over all height increase.
2fast4u
2fast4u
Would the Wildtrak be the highest of the models?
BuckeyeinNV
Henderson NV
4Runner
If by highest you mean tallest/most ground clearance, there is no difference between the Wildtrak and any other trim with the Sasquatch package as far as I can tell.
frinesi2
MD
'92 Pajero 2.5TD, '99 Land Cruiser '15 Golf TDI
Wildtrak = fast desert
Badlands = slow technical
Outer Banks = overlanding
They can all be spec'd to an equally high level.
