- Banned
Is this the tie rod on a Jeep or a front stabilizer? Because if this is the tie rod then I’m completely jealous… and I see why Ford has so many issues.
It’s a Rubicon 4xe, has 2H and a 4A yeahYes that is the tie rod, that jeep either has the full-time 4wd option or is a 392, it has CV's and not u-joints.
Yeah well I was already jealous of thatKinda glossing over the fact that Jeep has a solid front axle... Litteraly a completely different animal.
Yeah Jeep has a completely different setup so you can't really compare the two. Kind of curious why you got a Bronco though if you wanted a solid front axle. One of the big reasons why I didn't buy a Wrangler is because it has a solid front axle.Yeah well I was already jealous of that
Well said, I came from the Jeep side and am very familiar with: upgrade, break something else, upgrade. Rinse and repeat!Yeah Jeep has a completely different setup so you can't really compare the two. Kind of curious why you got a Bronco though if you wanted a solid front axle. One of the big reasons why I didn't buy a Wrangler is because it has a solid front axle.
But anyway, on many vehicles--but especially independent front suspension vehicles--the tie rod is the "fuse". It's designed to break first so you don't damage other components. Once the BroncBuster folks added braces to the tie rods, they effectively bypassed that fuse, and they quickly found they were damaging the steering rack. So they had to beef that up too.
It's the curse of off-road vehicles, and Jeep owners know the game well. You upgrade one component, you find a weak link in another component. You upgrade that component too and you quickly find there is yet another weak component. Rinse/repeat until you've spent tens of thousands of dollars on upgrades.
Going off of the fact that you didn't know what that was, it's very easy to assume that you've never experience death wobble. Try that at 60 mph and report back about your jealousy of a solid axle.Yeah well I was already jealous of that
Not sure I would go that far, I have never experienced death wobble (which was a good thing) in any of our Jeeps, even at 90+ MPH. Death wobble is not a certainty but is extremely common.Going off of the fact that you didn't know what that was, it's very easy to assume that you've never experience death wobble. Try that at 60 mph and report back about your jealousy of a solid axle.
It needs a tie rod that big to fight death wobble. And yet they all still get it - especially if they have tires bigger than the basic 31” and/or they are used for much actual off roading.Kinda glossing over the fact that Jeep has a solid front axle... Litteraly a completely different animal.
