Is this a weird question? 2 Door Sasquatch vs. Non Sasquatch Rollover?
mlcinema
US
Off Road
Hello,
Bronco will be my first higher riding SUV or off road vehicle. Is there any issue with rollover on the highway? 2 Door Sasquatch vs. non Sasquatch?
Not that I’m going to be going 100mph or anything. Just wondering.
JeepersCreepers
Ryan
Sparta, NJ
Jeep Wrangler TJ
Rollover is always possible in any vehicle, but to allay your fears somewhat: the CG (center of gravity) is much lower than you would expect. On a Jeep the CG is colocated with top mounting bolt on the transmission bell housing which is below your rear end. Of course the opportunity for rollover is increased when cornering at speed in a vehicle with a higher CG but in normal driving (and even in normal wheeling) the opportunity for a rollover is much less than what you might imagine. The more time you spend off camber the more comfortable yet get with it.
mlcinema
mlcinema
US
Off Road
A lot of technical in there, but I do understand. Thank you.
North7
North Texas
SUV
The Sasquatch will only be 1/2 - 3/4 of an inch taller, that is not a significant amount to raise the CG. Fords lawyers would not let them open themselves to unnecessary rollover lawsuits, you should be fine if that's what you want.
pan-y-cerveza
Manitoba
Tacoma Pro
I'm not a vehicle or math expert but I wonder if the CG is actually lower on Sasquatches with the added weight of tires and mechanicals.
Steamroller72
William
WNY
2018 RAM Sport Quad Cab
No drifting!
mlcinema
mlcinema
US
Off Road
Makes since.
North7
North Texas
SUV
Excellent point, I think your onto something. The Sasquatch may have 5-10 lbs additional suspension weight and 10-20 lbs additional tire weight per corner.
This additional 60-120 lbs carried very low as far as CG goes should offset the additional tire height so the rollover risk maybe very similar between the two.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
The higher the center of gravity, the greater the risk. Increased track width helps, but everything will flip given the right circumstances.
MadMan4BamaNATL
Ray
Atlanta
A higher riding vehicle will roll much easier than a low vehicle. Think sports cars and the dynamics of lift.
However, from the factory, even the Squatch isn't riding too high for the purpose of not selling the Bronco unsafe out of the door. Now, saying that, if you then mod your Bronco to ride higher, then you're taking some risk.
Think most of the danger on the highway will come with the mud terrain tires when driving at speed and need to perform an emergency maneuver. The Bronco will certainly not perform as well as my 440i on 19" Michelin Pilot Sport 4 Summer rubber on an M Sport adaptive suspension, but I wouldn't expect the Bronco to perform as well. Thus, I will not drive my Bronco in the manner which I drive my BMW 4 Series. Not even in the manner which I drive my wife's X3 40M with a similar performance suspension and tire set up.
Bronco is an off road vehicle on Squatch, it really is, so drive it in the nature of the vehicle and you'll be safe. This means drive slowly or just slower than you would your car or pickup truck that rides on regular touring tires. MTs are a different beast on the highway, as they are loud, and wandery so respect it and live to tell the tale.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Used2jeep
Massachuvian
2007 Crown Vic P71
