Issues / glitches during 2021 Bronco startup -- "Check brakes," "trail turn assist unavailable," and "hill assist unavailable." error messages
Hartzco
Valparaiso, IN
2021 Bronco BD Sasquatch
Dealing with the same issue. Happens with the doors off whether I’m belted or not. My only workaround is remote starting it before I get in. I’ll take it into Ford soon. Seems like I can release the e-brake and continue on every time without issue so I haven’t freaked out.
Ilmguy1234
Tyler
Wilmington, NC
Jeep Wrangler/Chevy Tahoe
+1 exact same. Hopefully more visibility = quicker resolution.
gtx_bronc
GTX
So I had the doors off today, and drovr around 75 miles total. Around lunch, I jumped in the Bronco and started it up. It kicked "Check brakes," "trail turn assist unavailable," and "hill assist unavailable." The traction control may have faulted too, along with the ABS. I turned it off, waited about ten seconds, and turned it back on. It started fine, but the E brake was engaged. I disengaged it and all was fine. It did it one other time, out of probably 10 startups total.
I wonder if the fault is in the door electrical connections. Maybe the system senses the doors are off and it sends a fault. The other glitches I have read reset when the doors were opened, and mine has only done it with doors off.
Overall, not a huge deal, and probably to be expected with a new and first-year vehicle.
This exact thing happened in n mine tonight for the first time. Turned it off and back on and everything went back to normal. I didn’t have the doors off fwiw.
Homerb
Homer
Santa Ana
rx
Had the brake light turn on today. Will take it in for service this week and will post the dealer’s resolution.
PaulMedik
Paul
Charleston, WV
www.valleysportspics.com
2021 Bronco Big Bend, 2022 Wildtrak
Homerb,
What was the outcome? My check brake system warning came on today while driving on the interstate. Now the brake light is on. 1115 miles on the odometer.
mpeugeot
Although, it should not need to be standard equipment, I would suggest that you consider getting Forscan and learning how to use it. You can read/clear some pretty complex faults with Forscan.
JDS
Massachusetts
TT Roadster, Reatta convertible.
I suppose that is better than the “bronco unavailable” warning light I keep getting. I look forward to re-learning the hokey pokey so I can get the vehicle to operate....
PaulMedik
Paul
Charleston, WV
Drove to work this morning with no brake light and none on the drive home. Hopefully it was a one time glitch.
Of note, the software on my Bronco was upgraded Wednesday and my radio clock is no longer accurate...again.
mpeugeot
Would you like to upgrade to Windows 11? ;)
mpeugeot
mpeugeot,
Upgraded to Windows 11 about a month ago; no issues.
Most people don't have any issues.
I was just giving it as a example of what any software update process, sometimes it is great, other times you have the exact combination of parameters that breaks everything.
Not everyone had the smooth transition from 10 to 11.
PaulMedik
Paul
Charleston, WV
mpeugeot,
Windows 2 to 3 wasn't so good, but 3.5 made it better. 95 to 97 was bad but 98 was better. Windows 7 I loved. XP not so much. I fully understand your analogy.
calgecko
Sacramento, CA
www.instagram.com
2021 Chevy ZR2 Bison V6
it's @Ford 's way of wishing you a Merry Christmas
LikeToTurnLeft
Matt
Phoenix
2015 Ford Transit Connect & 2007 F150 XLT
I have had this exact same thing happen twice now. Never taken off the doors. I just get in it like normal and start it. Sometimes it happens. Sometimes it doesn’t.
da_jokker
Jeep Wrangler JKUR
Yeah..I have 4 computers in my house and not a single one meets windows 11 requirements. Their stupid CPU requirement is going to piss off thousands of people.
